Question about Kodak EasyShare DX6490 Digital Camera
Charger blinks red and does not charge
Camera is 3-4 years old and charger is blinking red. We relpaced battery and get the same result. No charging and blinking red. I've checked all problems in the troubleshooting section and I don't believe the camera was dropped.
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Posted on Dec 07, 2008
SOURCE:
My battery charger , olympus LI-40C blinks red and does not charge battery
Buy an el-cheepo battery charger kit and charge the batteries.
the olymup charger doesn't like non genuine batteries.
Dec 30, 2011 | Olympus FE-20 Digital Camera
After charging tz3 battery and put in camera it
Are you using the batteries recommended by the manufacturer? that is a very important fact, even though you can find other batteries that have the same specs, they make the cameras to where it will work best, and sometimes only, with the batteries recommended.
May 20, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Can't charge the battery
I didn't have the time to find out what was the problem cause i needed the camera immediately so i bought a new battery and a new charger.Thanks for the help!!
Aug 07, 2009 | Olympus FE-220 Digital Camera
The red led of the charger is blinking.Is the
I assume you charging battery in charger when it blinks.
This means the charger cannot charge the battery, as the battery has been left too long discharged & annodised inside...new battery required i'm affraid!
Is the red light on the charger suppose to stay on or blinking for the battery to charge?
It is supposed to stay on. If it is blinking then your battery has gone completely dead. You can force the charger to charge the battery by applying a voltage (AA battery w/ wires worked for me) across the charging terminals while inserting the battery. You'll have to take the charger apart for this.
May 17, 2009 | Vtech Cameras
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Green LED is on = Carging is complete
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
244 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
