Question about Canon imageRUNNER 5020i Copier
Canon imagerunner 5020i paper jams
My copier has been jamming all the time and it sounds like **** when its running, was wondering if it was something that has been known to go bad on these machines. any help would be great. thanks
  • tgodliquor Oct 25, 2008
    Its right where the paper comes out of the machine, not sure where or what it is called. I was thinking it might be a broken tooth on one of the gears, but not sure which one. who knows when its been serviced and not sure on the brand of toner, I inherited this problem (started a new job and they asked if I could fix it) Thanks for all your input though I really do appreciate it. I'll check all the stuff u said. as for the service from a tech, don't know if that has ever happened and I can tell ya it won't happen for a while cause THEY'RE TOO CHEAP!! Thanks again
    Todd
    Scholar:
  • 56 Answers
Where exactly is the paper jamming in the unit? It would be helpful to know if it is at the paper feed units or within the imaging section of the unit or within the fusing and exit sections.
Many times paper feed problems can be caused by a faulty feed roller or roller bearing that is worn. Also have you tried other suppliers of paper for the unit? Are you using genuine Canon components (drum, toner, etc) or are you using 3rd party brands of materials?
It is quite possible that the unit has a gear with a broken tooth that is causing the noise. Without actually seeing the unit with my own eyes it is hard to say. When was the unit last serviced by a factory trained service tech?
Cheers,
Keith
Posted on Oct 23, 2008
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
Our shop's Canon ImageRunner 3025 shows a jammed paper error, but there is not jammed paper in the copier that I can see. So what else could be triggering this jammed paper error? Thanks, Seth
You need not to pannic.Those paper jams are always there... What you need to do is to check you paper arrangement in papers tray sometime rough arrange may led to paper jams everytime
Thanks
Omari Saburi
Mar 04, 2011 | Canon ImageRunner 3025 Black and White...
Canon imageRUNNER 2020i left door paper jam error.how to reset Tried to clean everthying,and there is nor paper jam.
I have a Canon ImageRunner I seem to have a paper jam. The red light is coming on showing the jam in the upper section of the machine but I have cleared all the sections I know to clear. I have turned the machine off and back on the jam light is still on. I can't find the Manuel to see what the problem is. What should I do?
Nov 29, 2010 | Canon imageRUNNER 2020i Black and White...
Canon imagerunner 11025iF. Cleared a paper jam,
there is a possibilty that one of the jam sensors is stuck and needs freed and or a piece of paper is blocking the sensor.
Jun 02, 2010 | Canon Office Equipment & Supplies
Paper keeps jamming in the paper drawer 1 and the right side. I have switched to paper drawer 2 and the same thing happens. Drawer is set to letter size but keeps jamming. What's the problem?
It sounds like you have something interferring with the paper path... Look for any small pieces of paper in the paper path, staples, paper clips etc...
If you can't find any then a service call will be the order of the day!
All the best! If I can help further please contact me : johno@execs.com
Oct 25, 2009 | Canon imageRUNNER 4570 Copier
Canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Apr 09, 2009 | Canon imageRUNNER 5570 Copier
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Nov 10, 2008 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5020i Copier Logo
116 people viewed this question
old marine
old marine
