Question about Gateway M-6843 Notebook
How do i reset my gateway laptop to factory settings without the recovery disc
1234s282
  • 144 Answers
SOURCE: Gateway Mx3228 drivers for my notebook
Download And install Gateway Update
It will find and download all of the available drivers for your product.
http://support.gateway.com/support/drivers/search.asp?ref=nofind&ct=fn&param=gtwupd.exe
Or visit This Link , select you produt and operating system to see the drivers
http://support.gateway.com/support/drivers/search.asp?param=mx3228&st=kw
Posted on Jan 29, 2009
SOURCE: How do I reformat MX6912 gateway laptop without
Download the UBCD and use that.
www.ultimatebootcd.com/download.htm
Posted on Feb 24, 2010
s4u311
  • 813 Answers
SOURCE: reinstalling XP using recovery disc
ur recovery cd has been damged thats y this earro is comeing
Posted on Jul 29, 2008
  • 48 Answers
SOURCE: ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
Posted on Apr 14, 2009
  • 8909 Answers
SOURCE: I use Gateway recovery utility to create recovery
Usually two DVD's make the set.
Posted on Mar 09, 2011
How to reset to factory settings mty toshiba dynabook t11
do you mean resetting the windows to the factory default? If yes, then you should re-install the windows OS via RecoveryDisc (you can create manually when first time load the windows OS) if you don't have the disc, try contact the seller / store you bought it...or simply order the disc online (many website provide it, but you have to pay them)...restore to the factory state is very simple, just boot it with Recovery Disc, follow the instruction, then let the disc do the rest...
Mar 02, 2014 | Gateway MT3705 Notebook
Factory reset
Use your recovery disc to reset your OS.
Nov 30, 2013 | Gateway Computers & Internet
I dont have the password for my hp laptop, how do i factory reset without password?
To reset password for your hp laptop you can try bootable HP System Recovery Disc to do factory reset without password. If you don't have system recovery disc then you can use Stellar Phoenix password recovery software to reset password. Once you are able to login with new password then you can easily factory reset your laptop.
Nov 02, 2012 | Computers & Internet
Can I dl or burn to disc the factory reset for my gateway nv5105u laptop? I have lost that CD
If you have lost the CD you can try to do a factory reset from the recovery partition. Make sure you haven't formatted or deleted any partition in the computer since your purchase.
Using the Recovery Partition to perform Recovery.
First turn off your computer
Turn on the system and keep tapping the F11 key
system will boot into recovery partition. Follow the instructions below:
  1. Boot into Gateway System Recovery - Press F11 to Start Recovery.
  2. On the System Recovery Menu screen, press the ALT+D keys.
  3. At the command prompt, type: D: and then press ENTER.
  4. At the D:\ prompt, type: CD Windows\i386 and then press ENTER.
  5. At the C:\Windows\I386 prompt, type: dir filename.* and then press ENTER.
  6. Verify if the file name has an underscore ( _ ) in the extension. Example: appwiz.cp_. If the file has an underscore, it has to be expanded. If it does not have an underscore, the file can be copied without expansion.
  7. If file has an underscore, expand the file to the destination. At the command prompt, type: Expand filename.**_ C:\Destination. Example: Expand appwiz.cp_ C:\Windows\System32
  8. If file does not have an underscore, copy the file to the destination. At the command prompt, type: Copy filename C:\Destination. Example: Copy atmadm C:\Windows\System32
  9. At the command prompt, type: Exit.
  10. Once back at the menu, click Quit. The computer restarts.
It should be reset to Factory settings.
IF YOU DO NOT HAVE ANY RECOVERY PARTITION OR HAVE DELETED THE PARTITION THEN PLEASE REVERT SO THAT I CAN HELP YOU TO GET A RECOVERY DISC.
Thank you for using Fixya..!!
Aug 05, 2012 | Gateway nv5105u Notebook
How do i reset my emachine t5048 to factory setting without the windows boot disc?
Some computers will have a recovery partition you can recover from it will prompt you as the computer is booting. Emachines are very low end computers and don't typically have a recovery partition. If you didn't create the recovery disc you will need to order it from Gateway's website as they own emachine.You can order recovery media from https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Oct 17, 2011 | eMachines T5048 PC Desktop
I set a password to my laptop and I can't remember what it is, how can I get to use my laptop again??
@pinkruthpink
The quickiest way to reset your password is to run System Recovery (aside paying someone from a local computer store and use a software to reset it). Gateway laptops have a built-in recovery mode on the system wherein you can restore the computer to factory default without using a restore discs. (please note that this will erase everything). The hotkey for the recovery is the ALT+F10 key. After you press the power button, you need to hold ALT key and then simultaneously press the F10 key.. Once the recovery menu has loaded, click Restore to Factory Default Settings.
Good luck
Sep 13, 2011 | Gateway LT2021u Netbook
How do you reset to factory settings on the gateway ZX4931-31e
Click on Start -> All Programs -> Scroll down to Gateway (or type Gateway in the line) -> click on Gateway Recovery Management -> click on rider "restore" -> click "Restore System to factory default".
May 05, 2011 | Gateway ZX493131e Notebook
Can i do a factory reset on a satellite a105 s2236 without recovery disc?
since in thosiba systems the restore partition is not there so you require the recovery disc to restore the system to factory settings
Dec 26, 2010 | Computers & Internet
I didn't get a disk to restore to factory in the box. Do I need to buy that seperate, from the factory?
Here's the support page from Gateway for your model.
http://support.gateway.com/s/Mobile/2009/Ajax2/MD26/MD26nv.shtml
And here's the user guide link (which you can find at the page mentioned above)
http://support.gateway.com/s/Manuals/Desktops/8513015.pdf
and below are the steps from the user guide which to me seems like the solution for your question.
To create discs, click (Start), All Programs, Gateway, then click Gateway Recovery
Management. To create recovery discs for your factory-loaded hard drive contents (Windows
Vista, pre-installed software and drivers), click Create factory default disc or, to create recovery
discs for only the factory-loaded drivers and software, click Create driver and application
backup disc. Follow the on-screen instructions to finish.
Dec 19, 2009 | Gateway MD2614u Notebook
Gateway M-6843 Notebook Logo
495 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
