Question about Danby DCD5505W Electric Dryer
Danby Dryer DCD5505 starts and stops continuosly
This Danby dryer was given to me by my sister-in-law who hardly ever used it. It seems to work perfectly except, approximately every two minutes it stops then restarts after a couple seconds. Inside is spotless, wiring is correct per the manual, lint trap is cleaned every use, vent pie is clear, and this occurs in all the drying modes and with various size loads.
  • Richard Nov 15, 2008
    I was told this is the ant-wrinkle feature by Danby, but I'm having a hard time with that. The dryer begins the stop/start routine immediately..completely wet clothing..and continues through the whole drying cycle. Then it has the anti-wrinkle mode it goes into. It could take 2 hours for a load of laundry to dry. If this is the design it seems very energy inefficient.
    Problem Solver:
  • 8 Answers
If the clothes are dry you may have that occur, but otherwise I am trying to figure out if it is the heat sensor. We have one that acts similiarly, and it does cut out if it detects the clothes are dry. Our unit is five years old, so I am trying to find a rep;lacement sensor switch and see if that makes a difference. Good luck.
Posted on Nov 15, 2008
ITS COMPLETELY NORMAL!!! THATS HOW IT WORKS.
Display doesn't light up
Check the power cord is tight. and check that you have 220 volts then contact me back
Jan 20, 2014 | GE Profile Harmony DPGT750EC Electric...
My inglis dryer don't work as if it's not getting any power.
make sure the bulb is good.the internal wireing needs to be checked for any disconnected plugs or broken wires.you can alos check a small white thermal fuse on the blower wheel housing located behind the rear panel on the left side of the machine.if this is bad you will not have any power to turn the unit on.you can disconnect the two small wires from the fuse and connect them together and then try and start your machine.
Sep 18, 2009 | Dryers
My Danby dryer dcd5505w hums but wont tumble. I opened it up and pushed it and it ran for a bit and stopped. I pushed it again and it ran for about 3 minutes before stopping. The motor is okay and so is...
the motor is most likely the cause. once it starts to hum, it's not spinning :( bad brushes inside. replace the motor or get new dryer, sorry :(
Joe
Aug 26, 2009 | Danby Dryers
Dryer belt PH 1930 for danby model dcd5505w-1
Call Danby Customer Service at 1-800-263-2629; The part costs $25 or so plus another $7 shipping. Better than getting it through a distributor, I was given a price of $40 through a local place.
Oct 30, 2008 | Danby DCD5505W Electric Dryer
Danby dcd5505 dryer belt replacing
remove the bottom and/or front panel. The top panel will need to come off as well. The belt should go around the drum that holds the clothes and a drive wheel at the bottom of the machine.
Jul 03, 2008 | Dryers
Danby dcd5505 dryer
remove the front panel(s) and the top panel. the belt will go around the drum to a drive wheel at the bottom. the belt turns the drum. You will have to route the belt around the drum and go either in front of or behind the drum to get the belt installed correctly.
Replacing bryer belt
Please CLICK HERE this will fix your problem.All the instructions are given step by step with the diagrams.
Jul 03, 2008 | Danby DCD5505W Electric Dryer
Danby spin / washer
Danby DTT420 W
Mine just stopped working on gentle cycle and will only go fast in one direction on normal. Worked fine when I put it away.... :(
May 18, 2008 | Danby DTT420 Top Load Washer
Danby DCD5505-w1 Tripping Internal Breaker "Limit Switch"
Sounds like you may have a lint clog somewhere either in the dryer, or if if you have it vented in the vent. The limit switch is tripping due to an overheat situation. The dryer must have proper airflow to function properly.
Apr 12, 2008 | Danby DCD5505W Electric Dryer
Part Number DB-6060532 available at marcone.com
Mar 18, 2008 | Danby DCD5505W Electric Dryer
Danby DCD5505W Electric Dryer Logo
201 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
