Question about Panasonic SC-AK25 Shelf System
Help! My system just powers off and the display shows F61. After removing the power cord for a few seconds then plugging it back in...it works fine...for a while then does the same all over again! Any help? Cheers.
2 Suggested Answers
SOURCE: AFTER A FEW SECONDS MY
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Posted on Dec 08, 2010
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
PROBLEM F61 ON MY EQUIPMENT AND SHUT DOWN
You possibly took out the output ic by crossing speaker wires or touch one to the case when the other was in the terminal. (turn off and unplug when moving speaker wires)
Before taking it in remove all wires unplug power cord wait 30 seconds and plug just the power cord and turn on. If it still goes to f61 it's going to most likely need the output ic replaced.
$70-90 labor and about $100 for the part.
Nov 11, 2009 | Panasonic Home Theater System System
Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
May 20, 2009 | HP Photosmart C8180 InkJet Printer
Code f61
the f61 code is an audio code for panasonic first make sure all connections are correct and tight for spearkes...at the base if unit has base and with connections in back of unit and are fully in to connection terminal...make sure speakers are on and not on mute ...sometimes though you may have to re strip the wires to get into connection termianl in the back of the unit if that does not work call panasonic 1-800-211-PANA(7262) for more technical support
May 15, 2009 | Panasonic Audio Players & Recorders
Starting up
1. Plug the printer directly to the wall outlet.
note : do not use any power surge. just plug the unit directly to the wall outlet
2. Reset the printer by unplugging the power cord at the back of the printer while its still on. Plug the power cord after 30 seconds
Aug 08, 2008 | HP Photosmart C4180 All-In-One InkJet...
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Display showing "F61" some electricity failure
you have a problem with speaker cords:-
1-make marks with tape or any marker pen in all speaker cords(left-right-sub- front-rear).
2-after marking remove all speaker cords.
3-insert them one by one until f61 appear.
4-the cord that connected and make the trouble is bad please change it with new one.
Mar 07, 2008 | Panasonic SC-HT75 System
F61 problem
DIsconnect sound Amplifier ic (RSN).After removal of the ic if the unit works o.k offcourse without sound than replace ic.If still f61 than sound ic is o.k and check voltege regulators in power supply.You can check dc detect line if it gets activated.
F61 is mainly two resons 1st sound ic or power supply problem in power bord which send signal to system control to shut down the power in order not to damege more.
Dec 13, 2007 | Technics SC-EH780 CD Shelf System
Panasonic sa-ak25
the problem is F61 is speaker protection mode on.
fault with your audio power amp section.
i can help you.
nuwan.
Oct 09, 2007 | Sony MHC-G100 Shelf System
My Panasonic SC-A240 shuts down displaying the error f61.
Several components in the power supply maybe faulty, especially Tranisitor Q5110, Resistor R5114 and Diode D5102 on the power supply board. Check and replace these and also resolder the regulator IC's on the heatsink.
Sep 05, 2007 | Panasonic SC-AK240S Shelf System
Panasonic SC-AK25 Shelf System Logo
20 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
