Question about Whirlpool Refrigerators
Manual for whirlpool refrigerator model # GS6SHAXMQ00
Mom pushed the lock out button on the door, now we can't dispense ice or water.
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
Sea Breeze
  • 4654 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? appliancepartsse@yahoo.com
Posted on Jun 05, 2009
  • 9 Answers
SOURCE: Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Posted on Jun 23, 2009
Whrilpool side by side refrigerator control pannel does not work
Silly thought but cntrl panel could be locked. Check that the child lock is off. The bracket that holds the microswitches in the dispenser area could be broken. Wire harness at door could be disconnected. what is the model number?
Mar 11, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dispensing ice not working but makes ice fine and water works also
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button
is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your
refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to
troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others
must be repaired by a professional.
1. Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2. Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is
closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not,
this means the motor is frozen.
3. Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Have a nice & a happy day : ).
Aug 15, 2011 | Kenmore Refrigerators
No water and ice dispensing
most dispensers have a hidden lock button that may be set the lock button is a child safety feature,despite that could be the door switch since they wont dispense with the door open or perhaps could be the switch on the dispenser cradle
Jul 18, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser/water dispenser in side by side fridge not working
Your dispenser is child locked. Hold the child lock button for 4 seconds and the key should disappear, if you do not know which key to press I will need the model number from the tag located on inside of the fresh food section top right corner.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Ice dispenser not dispensing.
the hex wrench your after is know as nut ddriver screw drivers / you can remove the auger assembly quite easily the activation switch is located in the door assemby. be carefull the auger is powerfull.
Aug 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice Will not dispense
Check that the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the "Unlock" or "Locked" button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.          http://whirlpool.custhelp.com/cgi-bin/whirlpool.cfg/php/enduser/std_adp.php?p_faqid=110&p_created=1147725595&p_sid=lTIkCMOi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzEmcF9wcm9kcz0xOTkmcF9jYXRzPSZwX3B2PTEuMTk5JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9d2F0ZXIgZGlzcGVuc29y&p_li=&p_topview=1
Oct 13, 2007 | Whirlpool GC5SHEXN Side by Side...
Refrigerators Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
