Question about Sony Playstation 3 (PS3) Console
PS3 DOLBY DIGITAL ISSUES
When I put a game into my PS3, it plays the game in dolby digital automatically. I put a blu ray movie in and all I'm getting is Pro Logic. I've messed around with my settings but can't figure it out. What am I missing?
Scott
  • sharms88 Oct 23, 2008
    I did have Dolby Digital for awhile with my blu ray after messing around with my settings but can't remember what I did.
  • 4 Answers
In the PS3 menu, open Settings > Video Settings > BD/DVD Audio Output Format (HDMI) or (Optical Digital) depending on which one you are using. Set the type to to Bitstream (Linear PCM does not send the DD stream through).
Posted on Jan 18, 2009
  • 4 Answers
I am assuming that you are hooked up to an amplifier via a optical cable.
My guess for the Blu ray problem is, if you have an older amplifier that doesn't support the new digital HD sound codecs such as DOLBY DIGITAL HD and DTS HD, your amplifier will revert back to stereo or Pro Logic depending on how your amplifier is set up.
As for the Dolby Digital part, as you said, it does it automatically. Most games have Dolby Digital set up as the default audio output and the only real way to change that should be in the game itself. There are very few games that I have found that support anything other than Dolby Digital.
I hope that helps.
Posted on Oct 23, 2008
My PS3 has no sound when game starts. It does have sound before game. Also, the Blu-Ray movies skip & dont play.
It sounds like the sound signal type might be incorrect. I'd go into sound settings in the options menu, and when it asks whether you want manual or automatic, choose manual. Tell it to send regular PCM audio instead of the default Dolby settings, and see if this fixes your issues.
Mar 16, 2011 | Sony Playstation 3 (PS3) Console
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Can't get 5.1 audio from bose surround system using PS3 blueray
Yes but first thing, the blu-ray disc you are playing must be 5.1 to get true 5.1. If it is an older movie/TV show, then it might be only 2 channel audio. If this is the case, then your Bose system needs to create simulated 5.1 surround sound, which is not true 5.1. However, if your blu-ray disc is a true 5.1, then your PS3 needs to be set to output 5.1. I am not familiar with the PS3 so I am not sure where to located that setting. Also, try other blu-ray discs.
Apr 25, 2009 | Sony Playstation 3 (PS3) Console
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
Not showing DTS MASTEr OR DG True HD
In the menu is an option for switching master and true hd on. Standard its of and played als normal dts/dolby.
also: check the input (blu ray?): maybe it is set to only output no high def signals, so the amlifier doest recieve hd sound..
Igor
Dec 14, 2008 | Audio Players & Recorders
No dolby digitaL ON BLU-RAY FIMLS played thro a ps3,
prologic is a form of dolby digital, the 4.0 or 5.1 (versions I and II respectively) to be exact. the type of dolby version is determined by the source disk. the reciever may expand a dolby digital signal into 7.1 but it is actually a 5.1 standard, as is prologicII
Nov 28, 2008 | Denon AVR-3801 Receiver
NO SURROUND SOUND WHEN PLAYING BLU-RAY
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,300 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
