Question about Whirlpool Washing Machines
AWM5145/5 fault finder
Washing machine stopped at spin cycle with two towels in. Removed towels. Machine will not work. No water comming in. Checked water supply OK Fuse in plug OK When timer is put on B the timer clicks pump runs drum does not go round. Belt OK?
Timon90
  • 126 Answers
SOURCE: washing machine
Check the brushes in the motor.
Posted on Jan 28, 2008
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Posted on Feb 02, 2008
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
SOURCE: Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
Posted on Jan 18, 2010
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
How to fix drain-spin problem after overloading in wash...?
Owner's manual no manual? Try MFG website or email their customer service, or try
manualslib.com
Warranty still valid? try that, Also could be a
"hidden" recall. But the MFG definitely needs to know about these kind of problems.
Apr 13, 2015 | Washing Machines
MACHINE WITH AGGITATE BUT WILL NOT SPIN DURING SPIN CYCLE AT THE END. CLOTHES ARE DRIPPING WET
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Inthis case as the final spin is not working the voltage to the motor at the time of the cycle must be checked to confirm the fault of the main program controller . Also the drainpump must work after the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin. If the drain pump is clogged and not working there will be residual water and so SPIN MIGHT NOT WORK.
cleaning drain pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 21, 2011 | Washing Machines
My estate washing machine will not spin out, all of the other cycles work correctly.
Hello
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Mar 25, 2011 | Estate Washing Machines
My wife over loaded the machine with towels. it shut down in the rinse spin. I pulled out all the towels and tried to drain it by just running the spin cycle . It pumps water out for about 15 sec. and then...
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 22, 2011 | Fisher and Paykel GWL11 Top Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Intermitant fault zanussi zwx1506w washine machine
try these two things first:check the brushes on the motor you will have to remove it first they are held on with two screws on each,and also there is a drain filter behind the kick plate at the bottom of the machine if this is blocked it does sometimes cause the machine not to spin properly hope this helps
Mar 06, 2008 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
