Maytag bravos top load washer error code F1
When trying to wash clothes the washer will kick off with error code F1 after restarting 2 or 3 times it will then work
  • 10 more comments
  • winit Nov 05, 2008
    My washer just started doing this as well. It is 18 months old.
  • Nancy Wolfenbarger Nov 08, 2008
    My washer is also only 18 months old and has to be started 3 or 4 times to get it to wash. Otherwise the F1 code keeps coming on, the beeper goes off constantly. Happens again when about 15 min's left in cycle. Repair places in town will not touch it and say it will be extremely costly and that Magtag is out of business!!!! Any suggestions for help?
  • kafkaedge Nov 09, 2008
    mine is the same, 18 months old and I have to start it 4 times, then when there is 21 minutes left it beeps...I can't do a load of laundry without this happening....help!!!!!
  • Anonymous Jan 03, 2009
    Mine too. It takes 2-3 times to get it to start
  • pitpuppy101 Jan 19, 2009
    Mine just started doing this same thing, it keeps going to an F1 Error code. When I start it up, it goes to an F1 Error. Then I will Stop & Restart several times and then it will work. I am also experiencing this part way in the cycle. Luckly mine is under warranty with the company I bought it from. I will let you know if they say they can fix it and tell you how they can. Otherwise they will have to replace mine.
  • ricotexas Feb 19, 2009
    ditto, three trys and it starts up, then stops at the 21 min. mark. I haven't called for a fix yet, hoping it's nothing to serious
  • Kona11 May 25, 2009
    Code F1 at startup and then at 21 minutes when it starts a filling action. 18 months old and out of warranty. Just started doing it.
  • Charlie Lapinski Feb 27, 2013
    what is your model number is then we can get started then okay
    is the image below is your bravos
  • RHONDA CAMPBELL
    RHONDA CAMPBELL Jun 27, 2014
    Thank you for using the Better Business Bureau's Online Complaint System. Your complaint has been assigned case # 37049855. Filed against : Whirlpool Corporation Complaint Description: I HAVE A MAYTAG BRAVOS AND IT KEEPS SAYING F1 & UL. I AM NOT ABLE TO COMPLETE A LOAD OF CLOTHES IN A DAY BECAUSE OF THESE CODES. IT STOPS OVER & OVER SER # CU1771202 MODEL # MTW6600TB0. I HAVE READ ONLINE THAT SO MANY PEOPLE ARE EXPERICING THE EXACT ISSUE AS MYSELF. THEY NEED TO CORRECT THIS DEFECTIVE PART. I HAVE READ ONLINE THAT SOME PEOPLE ARE BEING HELPED AND SOME ARE NOT LIKE ME. I HAVE BEEN DEALING WITH THIS ISSUE FOR QUITE SOME TIME AND I WANT IT FIXXED. FOR ALOT OF PEOPLE TO EXPERIENCE THE SAME THING, IT'S SOMETHING THEY ARE DOING WRONG. I CALLED TODAY AND WAS ADVISED I WOULD HAVE TO PAY TO GET IT FIXED MYSELF. THIS IS WRONG. PLEASE HELP. Your Desired Resolution: I JUST WANT IT FIXED,
  • RHONDA CAMPBELL
    EVERYONE WHO HAS THIS PROBLEM PLEASE CONTACT THE BBB BECAUSE IF WE DO MAYBE SOMETHING WILL BE DONE. IT TAKES ONLY A FEW MINUTES.
  • RHONDA CAMPBELL
    AdYOU CAN DO EVERYTHING ONLINE. a Comment
  • 3 Answers
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
  • Anonymous Apr 11, 2016
    I called today with this issue and was told there is no known problem, which is funny when I see page after page of people complaining about my same issue. The part alone starts at $200 or better. To get someone out is another $140. By the time its said and done, you might as well go buy another new one...and wait for the 3 year mark and do it all over again. Bag that. Ill find me a better washer..and hopefully better customer service. I didnt care for the guy who flat out called me a liar.
My Maytag MTW6500 T failed after 2.5 years. The error code displayed is F1. I ran diagnostics and error code 68 and 72 showed up.
To fix do the following:
Call Whirlpool at 800-688-9900.
Let them know you have a Bravos or Oasis washer and you are getting a F1 error code.
They will send someone out to replace the controller board for free!
Replacement board number is W10189966
You may have a different number in your maching, I had a W10130544. The W10189966 is the current replacement for your board!
Best Greg
Posted on Dec 20, 2010
  • 10 more comments
  • boylookahear Jan 17, 2011
    This code is under recall when I called the 800 number above. They scheduled a repair company to come and fix the issue for free.
  • ghostgirl623 Feb 18, 2011
    You're awesome - I just called and did exactly what you said, and they're sending a service person out to replace the controller board for free. Thanks for posting this!
  • j_zadski Apr 21, 2011
    4-18-2011 Call Maytag about the F1 code on my bravos MTW6500 and basically told it will cost me $. Like at least 300. Got the washer in 2009. What a joke!
  • Matrix1960 Apr 22, 2011
    Just called the 800 number above regarding the F1 code on my Maytag Bravos MTW6600TQ0 washer. Service technical will be out next week to fix the problem at no charge.
  • ashleysdeals Jun 01, 2011
    We bought ours in 2007 and at 16 months this was the problem. and it wouldn't reset after unplugging it any more and we would have to start and re start 8-12 times eventually....We did this for nearly 3 years because we were not wanting to pay money because the warranty barely expired and I didn't want to give them the satisfaction of more money out of our pocket. Well we are fed up and tired of laundry to be taking sooo long to do and we saw that others had it fixed for free...so we made the call (before we knew it was free) and sure enough they are coming tomorrow to fix it free of charge...parts and labor FREE!! 6-01-2011 That is so exciting so I say call them again and make them do it FREE! By golly it's not our fault they messed up when making them!
  • Frankiefan Jul 29, 2011
    I made the call on 07/28/2011, they could not have been more helpful. I have an appointment scheduled in A.M., with NO CHARGE to me :0) Recommend anyone else having this problem, make the call...800-688-9900.
  • uaedeb Sep 13, 2011
    I have a Bravos washer giving error code 51. After reading this, I called the number and was told that while they do this repair for free on some models, of course mine is not one of them. I have called a repairman and am waiting for him to come. since either ther rotor position sensor or the lower harness has to be replaced, I'm expecting $$$.
  • Doug Nov 16, 2011
    Thanks for the Info.
    I also called the above Maytag phone number, and they are sending a service person to repair the washer with F1 error code for free.
    Sears, where I bought the washer, was going to charge $214.
  • Melanie Brents Aug 07, 2012
    I just followed this advice and called Maytag. Mine was purchased 5 years ago but was one of the ones recalled. They are sending out a repairman and said all parts and labor will be free! My faith in Maytag is restored!
  • ditzeree101
    ditzeree101 Nov 27, 2012
    They want money from me so i dont know how you got them to do it for free.
  • wayne939
    wayne939 Jan 07, 2013
    Called number. they are coming out in 2 days. hose and harness and or motherboard issue. all is covered.
  • Cyndy
    Cyndy Oct 25, 2013
    they will no longer send the part for free. they are owned by whirlpool
I'm also suffering from the F1 problem and have now had 2 extremely frustrating conversations with Whirlpool. They claim that the model number of my washer indicates that it is almost 4 years old (which is true), and apparently they believe that this is an acceptable lifespan for an appliance that cost almost $700. They 'offered' a repair service that would cover this part (the control board) and warranty the machine for one additional year for about $350. Then I called their parts supplier and learned that to have that board shipped to me total cost would be $250. I am disinclined to sink more money into a product that even the manufacturer won't stand behind, and will start my search for a new washer TODAY. And I am launching a full-on smear campaign against Maytag/Whirlpool for their 'customer service' policy that really doesn't serve anyone at all except themselves.
If this were a wear and tear part like a rubber gasket, I would understand that eventually it would need replaced. But this is an electronic component, unable to be affected by user error (and I have followed instructions to the letter with this machine since the day I bought it, regular cleaning, only HE detergent, etc.). I do not accept the answer that less than 4 years is the expected and acceptable life of an expensive household appliance.
When I moved into my house 4 years ago, there was a 20-year-old washer and dryer already here. They actually worked, but I wanted something more high-tech, so I made the mistake of donating them to a charity and buying the Bravos. I will not be making that mistake again, I will not be supporting a company that does not stand behind their products.
Also, the customer service supervisor did let on that OTHER model numbers of the Bravos did indeed have a free control board replacement covered...but not mine. Clearly it's the same problem afflicting the others...why would a reasonable company not expand coverage and stand behind their product? He also refused to transfer me to their legal department to discuss the class action suit that obviously needs to be brought against them.
For those of you still reading and experiencing this problem, you can hit "cancel" and the "start" button again and it will start refilling. You may have to do it a few times depending on how advanced the problem is. Mine started with one Cancel/Start cycle. Now i'm up to (no joke) TEN. I have to babysit my washer, as if I don't already have a full-time job. Also happens again at the end of the cycle when the tub drains then attempts to refill.
Whirlpool needs to do the right thing and back up their products, and admit when the electronics are defective.
Posted on Jun 13, 2012
  • 4 more comments
  • Jennifer Castro
    Jennifer Castro Sep 10, 2012
    Thanks Gregory. Still having not done anything to fix my situation that I posted about 3 LONG months ago, I called the number you provided today. That number apparently is customer support for front-loading washers. She documented my case and transferred me (after a 10+ minute hold time, I guess what I get for calling on a Monday morning!) to the customer support line that supports top-loaders. That number is 1-800-253-1301. Basically I was told (again) that "we're sorry, but this problem doesn't seem to be affecting your model/serial #". Oh. Clearly, I'm making it up. :( So I escalated to the customer svc manager and had to go through the same BS, the end result of which was finally her agreeing to give me a 50% discount on the part ordered directly through them. She gave me the name of 3 service companies (whom I will have to pay to come out here and assess the problem, then again to replace the faulty board). She said I need to make sure they give me the correct part #, since they do not accept returns on parts. I think I'm going to take the **** thing apart myself, give her the part #, make sure their discount is cheaper than getting it on Amazon, order it, and install it myself. I should really know better than to call them and expect any help, it's a great way to ruin a Monday morning and start the day frustrated.
  • Nancy Sep 14, 2012
    AdJennifer, I am having the same problem with my Bravos Model # MTW6600TQ0, top loading fancy dancy expensive washer. In fact, as I right this my washing is beeping and I have been running up stairs every few minutes to pause and then restart, There are others on different appliance boards with the same problems we are having and if they won't fix for free, I think we should start a class action suit. There is obviously a problem with the control board in our top loading washers as well as the front loading. I don't think we should be discriminatred against because we chose the top loading version! I had an extended warranty, believe it just went out recently (Already had to have the whole tub and wheel bearings? replaced when it was only a few months old. It started the stop and beep thing a while ago, probably while still in warranty but it only happened occasionally, now it is constant. It is taking me hours to get this load done, I might have to empty out the clothes. I will try to run it/ rinse it out without clothes just to be sure it is not a clogged tube issue. But I believe it is the control board because it is happening at end of cycle too. When I first bought this machine about 4-5 years ago, I decided to get the best quality, Maytag, and since it is a long term investment, I would go for the eco-friendly, low water use HE washer, despite financially needing a less expensive washing machine. I was looking for the long haul and thought it was worth it to spend more for a washing machine. After all, my Hotpoint washer lasted me from 1985 to about 2007 , 22 years! Perhaps we should all rebel against corporate greed and planned obsolescence and go back to wash boards or wash our clothes in the bathtub.
  • Mark Montague Jan 30, 2013
    I also have this issue with the F1 code on my Maytag Bravos washer purchased in 2007. Model Number is MTW6600TQ0. Just called the customer service number above 800-688-9900, told them I was reading about some recalls on some models. I had registered my appliace so they had my information. She stated that Maytag/Whirlpool would take care of the service call and part as a gesture of good will.
  • MaryS Sep 10, 2013
    I called both Whirlpool and Maytag about the F1 error. Both told me the board would be no charge but I would have to pay service and labor. The service company they scheduled told it it would cost at least $160. I am unemployed right now and don't have $160. So basically they sold me a defective washer and I will have to pay an additional $160 to fix their defective washer. I am totally fed up with whirlpool! It isn't fair. I aske if I could just have the replacement board sent to me and they refused because they said it had to be installed by a licensed techninian. So because I don't have more money to spend fixing their defect I stuck with a defective product. I'm wondering if I should contact the Att.. Generals office or the BBB
  • MaryS Sep 30, 2013
    Filed a complaint with the BBB and now Whirlpool is sending someone out to fix my washer. Thank you BBB, I've never done that before but it was worth it
  • Peachie
    Peachie Jul 12, 2014
    Glad to hear that you got your issue resolved. Maytag should have just addressed the issued completly from the very beginning!
Hi - I know this is a very old discussion, but the problem remains very real for Maytag (and apparently Whirlpool) owners. We have owned a Maytag Bravos washer for several years and only recently started having this F1 error problem.
After looking around the internet a good bit, I found the part and video relevant to making this repair (see below) BUT I also found another Maytag number that I called first. I played dumb saying I thought the machine might be part of a recall. A very nice woman with Maytag took all my information (model, serial, name, address, etc.) before ever really telling me anything but then said there is no recall but there is a program by which Maytag is "helping" on this issue. Yes, I asked whether "helping" means free repair, which it does. They are sending someone out tomorrow to take care of it.
So - the relevant information:
The number I called - 866-769-7260
If for some reason you do have to go the repair route, I think I found the appropriate control board for $150 (lowest price I found) at Amazon: http://amzn.com/B005B5RXL8
And the video showing the very easy replacement process is at: https://www.youtube.com/watch?v=3oFPRNYpSy4&
Good luck to anyone out there still having this problem!
Posted on Sep 04, 2012
  • 1 more comment
  • evanhjenkins
    evanhjenkins Dec 07, 2012
    Followed your advice for a Maytag Bravos washer and so far so good. They're sending someone out on Monday to do the repair. Thanks for the helpful info!
  • Cyndy
    Cyndy Oct 25, 2013
    Thank you for this very helpful video. Naturally, Maytag will not stand behind their products. So I ordered the part from Amazon and used the video to replace the part. It took 10minutes max. The washer is running great. I do have a problem with the buttons but I understand this is another part. The user interface? If you can direct me to the part and video for replacement Im willing to give it a try. Thanks for being such a great person and telling people what they need.
  • Gregory
    Gregory Oct 29, 2013
    Hi Cyndy - Glad this video was helpful but it's the only issue I had and thus the only video I located. You might want to try searching youtube for your specific issue. Sorry I can't be of more assistance on this other matter.
From the Maytag website not sure if it will solve the issue completely:
For BravosTM washers, check the following answers for error-code related issues you can correct:
The following list of codes indicates a possible electronics communication problem with the washer:
BravosTM washer - F1, F2, F40, F41, F42, F50, F51, F52, F53, F54, F72
To remove the error display, press Power/Cancel or Pause/Cancel twice.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, call for service.
Posted on Feb 19, 2009
To damonawsgt : i started reading this because the kenmore elite that i gave my daughter is having this F51 problem the funny thing is (well not so funny) the reason i gave it to her is that i bought that pretty red LG set you mentioned and right now as i'm writting this that pretty red washer is going and it is so loud when it spins it sounds as though a jet is taking off. i literally can't hear my tv over it and i'm not in a small house, my house is 4500 sq ft the laundry room is far on the other side of the house from me, it is **** !!!! if you have one piece of clothing to much nothing gets clean. save your money !
Posted on Nov 21, 2009
To get over the F1 Code problem with the Maytag top load washing machine: press pause/cancel, open lid, dump about half a gallon of water into the machine, close lid and press start. It has been working for me all the time. I have to do this at the beginning of the wash cycle and at the beginning of the rinse cycle. What a pain!
Posted on Jan 03, 2012
  • mina pizzitelli
    mina pizzitelli Sep 08, 2017
    I tried that and it works. Thanks. I've been having the F01 since May of this year. Service has changed the board 3 time and the tube once. The problem keeps getting worse. Now I'm waiting for Sears extended warranty to give me their solution. The Service says that the machine is not repairable. Like others I take excellent care of my appliances and follow all the requirements.
    Anyone have a suggestion on what brand to purchase. It seems like they are the same.
You will have to get the circuit board replaced to fix this. Mine went in less than a year they tried just resetting it that lasted one whole load. These machines are junk for the price dryer didn't even make it through 3 loads before it went out and of course the part was back ordered so was without a new dryer for months. Never again next time going for them pretty red LGs.
Posted on Sep 05, 2009
  • Hiedi86 Nov 27, 2011
    Mine is doing the same thing... I got mine and a year later the washe stopped working they came out fixed it and then a year later it started again and the warrenty was up.. has there been a recall on the washer?
I bought my Maytag Bravo on sale and really got a great deal. Then I got it home and one the FIRST LOAD got the infamous F:01 error. ON THE FIRST LOAD. My solution....I hauled that thing right back to the store for a full refund. Not even worth my time. I saw on another website that even if Maytag replaces the part for free you still have to pay for them to send someone out and replace it for you. I did take the top panel off and try the "easy fix" and I know I could do the replacement myself, but if it's messed up right out of the box I'm not going to waste my time and effort.
Posted on Jan 29, 2012
I have a Maytag Neptune Washer MOD%23MHWZ600TW00 that give an F20 code. The answers to the problem is to clean youe
hose inlet screens on the back of the washer.
Posted on Feb 10, 2010
  • 2 more comments
  • melanie h Dec 29, 2010
    We have the same problem with our washer, Maytag/Bravos. It's only 3 years old and started doing the F1 routine about 6-8 months ago. After a disappointing call with Maytag, they said there have been 'no software problems' with the appliance. They also scheduled an appointment with a local service provider, which we'll have to pay for. Total bummer. Tried to do the right thing by buying an energy efficient washer from a trusted brand and it's total ****. Not buying Maytag again.
  • Laura Bruckner Apr 03, 2013
    I called the 866-769-7260 number; they said "No recall but we'd like to send someone out to fix that error code for you". Works for me and I will buy a Maytag/Whirlpool appliance again! More than I can say for Toyota Corporation who is dogging me on an issue being recalled on trucks one year newer and above but not mine with the same engine! My washer is the top loader and was purchased in Feb. 2008 from a Scratch and Dent place.
  • Laura Bruckner Jul 11, 2013
    Update - July 10, 2013. Now the washer is throwing everything off balance and showing the UL code. It shakes so much that I now see all the dispenser cups on top of the wash tub have deep gouges in them, going to try calling Maytag again, I will post their response.
  • RHONDA CAMPBELL
    I AM ALSO EXPERIENCING THE F1 & UL CODES. I START WASHING IN THE MORNING AND BY THE TIME I GO TO BED I AM STILL ON THE SAME LOAD. BY THAT TIME I OPEN THE WASHER THEN FIGHT WITH IT AGAIN THE NEXT DAY. THIS IS SOOOOOO AGGREVATING & USING UNNECESSARY ELECTRICITY. MORE SO IT RUINS YOUR DAY KNOWING YOU HAVE TO FIGHT WITH THIS ISSUE EVERYDAY. I HAVE BEEN ON HOLD WITH MAYTAG AND I AM STILL HOLDING. I AM GOING TO REPORT THIS TO THE BBB. I HOPE EVERYONE ELSE DOES AS WELL. MAYBE WE WILL GET THIS RESOLVED IF WE ALL REPORT.
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Maytag Bravos error code f1
    F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
    Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
    The F! error code keeps coming up when I start my washer
    F1 means communication error, the best thing to do is unplug unit for 2 mins and try again
    Jan 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error code on Kenmore Oasis He
    Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
    Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    F1 error code on cabrio washer
    CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
    WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
    T W
    Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
    Hope this helped.Let me know by rating me
    For more help go to live chat.
    lenwest
    Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    How do you open a Kenmore Elite Oasis top-loading washer?
    I just finished installing my new control unit for my Kenmore Oasis and my F1 problems are GONE! I ordered it from Sears Direct Parts. With shipping and taxes it came out to about $174 for the part, but our issues are gone and now we can wash a load of clothes without having to reset it several times.
    Mar 18, 2008 | Washing Machines
    F11 code Whirlpool Duet GHW9300PWO Washer
    well your close f11 is a motor control unit error or a loose connection in the wiring harness from the mcu to the motor or from the mcu up to the control panel the mcu is under the bottom kick panel un plug the washer safety first then start at the motor follow the wires back to the mcu checking wires and connectors then form the mcu up to the control board check your motor for continuity normal should be about 6 ohms between pins 1&2 then same at pins 2&3 same at pins 1&3 your motor maybe overheating and tripping out on overload then restarting when the washer motor cools down if all that checks get back with me and we will run diag on it
    Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    38,125 people viewed this question
    Top Washing Machines Experts
