Question about Ac Delco AM-FM Radio Cassette
2002 chevy pickup radio wiring diagram
Clock will not keep right time when you turn the truck off
  • 54 Answers
I found the sollution for the radio and car Mp4 player with FM transmitter from the internet, however, I forget now. I am so sorry.
Posted on May 07, 2012
I need a radio wiring schematic for a 2002 ford crown victoria
It may need the accessory wire powered for clock check wire diagram
Dec 22, 2013 | 2002 Ford Crown Victoria
Installing stereo in chevy s10 pickup now my gauges aren't workign
Did you disconnect the stereo wires you'd hooked up and see if everything went back to normal? It's easy to connect some custom equipment to the wrong wire. Depending on the stereo you installed, there would probably be 3 wires that are battery positive at any time, and at least one ground wire. There's a wire that's "hot" all the time that provides power to keep the station memory and clock, etc., set. Then the wire that actually powers the radio when you turn it on. The other wire would be hot FROM the radio when oyu turn the radio on, and it's meant for cars that have an electric antenna so the antenna raises automatically when you turn the radio on. If you connect either one of those wires to the wrong wiring harness wire, you can have power to something at an inappropriate time. The best thing to do (without cutting the harness wires) is to use the proper power leads in the factory wiring harness. Otherwise, if you look at your truck fuse-box diagram, you should see that one fuse is marked like "constant battery". I think that will be the fuse towards the front of the truck in the very bottom row of fuses. The wire for your station memory/clock can go to that fuse. The fuse towards the BACK of the truck in that same row is "radio/ignition". THAT fuse only sends power when you turn the ignition switch on or to accessories. Use it for the radio power. If you don't have an electric antenna, don't bother with that wire. To wire straight to a fuse, you need to determine which leg of the fuse power comes in on, then strip about half an inch from the wire and wrap it around the leg of the fuse that goes in the OTHER side. That way your system is protected by the fuses. If/when all that is done, you may have blown a fuse or relay in the big box under the hood on yop of the left fender-well. Let me know if you need help still, but as this problem is 4+ months old, I imagine you fixed it already. bushman_dread@msn.com
Mar 24, 2012 | 1999 Chevrolet S-10 Pickup
Where can i find the stock wiring diagram for a 89 chevrolet pickup radio
I assumed full size truck?
1989 Chevrolet Truck Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blu
Sep 30, 2010 | 1989 Chevrolet C1500
2002 Chevy Tracker: While unplugging my gps cord from the cigarette lighter, the cigarette liner popped out (the entire cylander that's attached to wiring). At the same time, my radio immediately stopped...
Sounds like the hot wire grounded when it came out. Locate the fuse and replace the fuse for that and the radio and everything should come back on.
Jul 07, 2010 | 2002 Chevrolet Tracker
Radio resets to AM
Take out your radio and make sure that the memory wire is getting a good connition(yellow wire)
Apr 08, 2010 | 1998 Chevrolet S-10 Pickup
How do I remove fuse for clock/radio '05 Aveo
I have looked and looked for this myself. I belive since one of the wires runs to the ecu. for the acc power it is branched off of some other . If you need a good reliable place to pull power. Use the power windows Breaker / fuse its on the passanger side it is on acc power for the key.
The other Direct battery feed for the radio is protected in the left fuse box on the drivers side.
Mar 31, 2010 | 2005 Chevrolet Aveo
Radio wiring diagram for a 1998 chevy s10
1998 Chevrolet S10 Pickup Stereo Radio Wiring Diagram.
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Dimmer Wire: Brown
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 4′ x 10′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Nov 11, 2009 | 1998 Chevrolet S-10 Pickup
Looking for speaker and radio diagrams for 97 chevy S10? Thanks
THIS IS ALL I HAVE, HOPE IT FILLS THE BILL FOR U.
1997 Chevrolet S10 Pickup Truck Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Right Rear Speaker Negative Wire (-): Light Blue
Nov 11, 2009 | Chevrolet S 10 Cars & Trucks
Puttin new speakers i dont know what color the stock speaker wires are
2002 Chevrolet S10 Pickup Car Stereo Radio Wiring Diagram
Car Radio Switched 12v+ Wire: Dark Green
Car Stereo Dimmer Wire: Violet/White
Apr 16, 2009 | 2002 Chevrolet S-10
Car Audio & Video Logo
257 people viewed this question
Top Ac Delco Car Audio & Video Experts
MarcellusA
Level 1 Expert
Are you an Ac Delco Car Audio and Video Expert? Answer questions, earn points and help others
