Question about ViewSonic VA720 17" LCD Flat Panel Monitor
85738000089 1 Vizio 32" LCD HDTV with Digital Tuner, VW32L
Will not power on...
    Champion:
  • 293 Answers
Hi...there,
YEah....It's seems every one had that same problems... faulty backlight inverter. If you are still under warranty returned for a new inverter or repaired it yourself...
Posted on Oct 23, 2008
Should i have a built in digital tuner
Your TV does have an inbuilt Tuner. You will need a Digital compatible Antenna. There is a big difference between digital and the old analog TV Antenna's
Hope this helps :)
Cheers Peter Smith
Apr 05, 2015 | Vizio VW32L 32 in. LCD HDTV
Last night loud boom, now TV wont turn on. The VIZIO logo is yellow when its plugged in, but wont power on.
90% the board that the power a/c plug into it.That the power supply board is dead.Take the tv aparts,searches this board for common problems dead capacitors parts,that burst open.10% after replacing capacitors or rplaced the whole power supply, still have the same problems.The Tuner board also dead,because of massive power surges.This board,that the board,where the incomming broscasting signal plug into it.Needed also to be replaced to solved this problems.Tries websites like Shopjimmy.com,Ebay.com to both refurbishes Power supply board and the Tuner board.Or either one.
Aug 10, 2010 | Vizio VW32L 32 in. LCD HDTV
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
I have a vw32l hdtv 10a vizio and the screen is black when i turn on.
These seem to have unreliable power supplies, so I would suggest starting there. If you are capable of measuring outputs, they are conveniently marked. If you are not, any TV repair shop should be able to check it for you. Check with Vizio directly for parts. They are the cheapest source I was able to find for replacement parts. The supply for mine was a mere $82 when most online sources were up to $100 more.
Jan 04, 2010 | Vizio VW32L 32 in. LCD HDTV
POWERS UP BUT NO PICTURE
It can be bad backlight inverter board or the power supply is not supplying the 24vdc to the inverter board.
Oct 28, 2009 | Vizio VW32L 32 in. LCD HDTV
My Vizio VW 26L loses all the digital channels when it is turned off. It works fine after a channel scan, but when it is off then back on there are only analog channel available. Bad tuner?
Tries different antena like a roof antena,or digital antena get better amplication input for receptions,still have signal not ur DTV tuner.
Sep 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Cant get surround sound system to work with vizio vw32l hdtv. which audio out plugs should i be using?
depending on the exact model but it should be just the optical output located on the far right side of the TV facing from the back.
Jun 04, 2009 | Vizio VW32L 32 in. LCD HDTV
How do I receive anolog stations on my VIZIO tv
you need to go into the menue, under setup and chanels, do the auto program, it will memorise all the chanels that you can get, analog, and digital, after that, just type in an analog chanel, if it goes to a digital chanel, hit the chanel down button
Jan 11, 2009 | Vizio L32 32 in. LCD HDTV
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
69 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
