Question about Samsung ML1740 Laser Printer
Paper jam/lockup I'm on my 3rd Samsung in 4 years. Models ML-1710 and MS-1740. After a little over a year, each one fails with a paper jam and the paper stops feeding altogether. My latest (and last one I'm ever gonna buy - I mean it this time :) is starting to make paper jamming/crunching noises. I'm thinking I should try the 12-foot drop-fix. Any other suggestions? :)
  • Anonymous Jan 12, 2009
    I own a Samsung ML-1740, also. I bought it about 1.5 years ago and it worked beautifully!! UNTIL.... about 3 months ago it started getting paper jams (or at least the printer thought it was getting them). There was never any paper caught, but if I removed the paper tray and put it back in, the document would print just fine. At first it was an intermittent problem, only occurring about once a week. This problem has been increasing in frequency and in the amount of effort it takes to convince the printer that there is no paper jam steadily since it first started.
    Have you called Samsung technical support about this? If you have, did they have any solutions for it?
    I am betting that there is something wrong with the rollers that grab the paper from the tray. They are either dirty or dried out or something like that. My temporary fix until I can buy a new one is to use the manual feed tray.
    I have definitely decided to buy a different printer. I am at least 90% sure that I will buy a totally different brand as well.
    Good luck with your printing problem. Please let me know if you find a solution or at least a description of what is causing the problem.
    Best regards,
    Karla
    (I think today is the day I do the 12 foot drop fix on mine
Check to see if the egg-shaped rubber feed roller is cracked. (Pull out the paper tray, it's in the middle at the front on top.) That's what I'm looking for now on the ML-1740. Seems Samsung used cheap rubber for the roller. It should only be a $.50 part if you can find one.
Posted on Jun 28, 2007
SOURCE:
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Samsung ml 1710 printer pickup more then two or three paper at one time
plz make it sure that the paper are not damp. if the paper is ok then your printer needs servcing
Aug 02, 2010 | Samsung ML 1710 Laser Printer
Online error light nothing prints
I have a ML 1710 .Not my area of expertise but I took out the paper and could not see a jam. Took toner out , a little cleaning, plugged and unplugged from computer several times. I found paper jammed in the very back ,folded so tight nothing was showing. Mine has a back door and the paper is having trouble rounding the last bend and coming out. So I leave the back door open to get my copies. Green light on.
Feb 26, 2010 | Samsung ML 2010 Laser Printer
How do i get the paper out; it is jammed with 2 pieces.
With firm steady pressure pull the paper out. Take the paper tray out and see if its clear behind it . Open the rear feed and check it also. If necessary remove toner cartridge and check there.
Oct 03, 2009 | Samsung ML 1710 Laser Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
Samsung ML-1710P Printer Problem
Most probably you took one of the paper sensors out of place. Any printer technician can happily put it back.
Jul 24, 2006 | Samsung ML 1710 Laser Printer
Samsung ML1740 Laser Printer Logo
737 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
