Question about eMachines W4685 PC Desktop
When I put memory in, it beeps at me & nothing comes up on the monitor
    Novelist:
  • 73 Answers
Is this a new memory module you are installing (are you REPLACING or ADDING memory)? How many memory slots does this computer have?
Make sure that the module is seated firmly by gently tugging at it after the locking mechanism is in place to make sure it doesn't fall off. Sometimes the lock engages even though the module is not correctly seated.
You may want to try the module on a different port and if it still beeps, the module may be faulty (if there are any other working and compatible computers to try it on, it will help isolate if it's the memory module or the motherboard's memory ports at fault).
If you have any other spare memory modules, you can try those as well. Whichever component (either motherboard or memory) the problem is isolated to will have to be replaced.
Posted on Feb 09, 2012
My desktop turns on but my monitor doesnt come on its plugged in right but my desktop just shows a light that its on
use other monitor..if it would not work listen for beep codes from your cpu.continuous three beeps meaning change your memory cards or check your memory cards..see if your monitor has light
Sep 01, 2012 | Gateway GT5220 PC Desktop
The satellite pro p300 will not start, power, charge lights come on, no beeps. The CD drive initalises. I can put a cide in and the light comes on. There is nothing on the laptop screen or the external...
Check the time if you can, doubt it since it can not display anything.
This usually happen when:
1. The memory card is bad, needs to be replace.
2. The video card is bad. Since it's a laptop, then the problem is with in the motherboard.
Sometimes when the BIOS battery is drained, it also stop the computer from displaying. To see the battery you must take apart the computer.
And the last thing in the list is the monitor it self. Maybe the monitor got damage some how and it won't display anything.
To troubleshoot, I recommend you start with the memory, and since the computer must be 64 bits, it needs 2 memory card of at least 2gb. each stick, if one of them is damage and both are still connected to the motherboard, the monitor won't display anything either.
May 27, 2012 | Toshiba Satellite Pro P300 Notebook
I get two beeps at start up with nothing on the monitor and then have to restart again and then it finially comes up after three to four restarts.\r\n it goes 2 beeps 2 beeps I took the memory out and put...
Two Beeps indicates "No memory modules detected" as outlined in the service manual. Either you have bad memory or you memory slots ( or motherboard memory circuit) are bad.
Jan 04, 2011 | Dell Inspiron 530 Desktop Computer
I get two beeps at start up with nothing on the monitor and then have to restart again and then it finially comes up after three to four restarts. it goes 2 beeps 2 beeps I took the memory out and put...
Have you tried installing them one at a time. It is most likely a faulty memory chip, however, it could be a slot as well. Try swip swapping them around to see if you can find a combination that works.
My Shuttle AV49P motherboard would not bootup. The system is powering up, & the drives are spinning up. There are no beeps & no infor on the monitor. Monitor is working, AGP Graphic card is...
You should get one bios beep. You seemed to have tried everything except a different hard drive. Check the capacitors to see if they busted open. Other than that the motherboard could be fried. Hank
Aug 18, 2010 | Shuttle AV49PN Motherboard
My Dell Dimension 4550 will not boot up...it sounds like it is but the monitor does not come on. There are no beeps. Power light comes on and the ''A'' light on the back blinks, if that means anything. I...
Well it's ur RAM memory. U need to clean it with alcohol & a soft cloth. Clean the gold coloured pins & place it back.
Note touch an unpainted metal part in your casing to discharge your electrostatic current from your body first, then perform the above.
It will be ok
Feb 08, 2010 | Dell Dimension 4550 PC Desktop
Turn on power nothing on my monitor, black ...
you semm have replaced any component in your motherboard eccept two, monitor and motherboard itself. try to put your new component in similar mother board begining with cpu ram vga, and put in output in same monitor (you must be hure that second motherboard is working) if nothing is coming try second monitor for output, if nothing is coming and have maybe beeps, one of your component that you have puted is defektive so try to replace them one by one. is not necesary to buy new component just try in other friend eith his parts afterthat if you finded defekyive component replace it in *********** board, (or if *********** board is defektive you must replace him, or monitor too if the problem is in monitor)
Apr 06, 2009 | Computers & Internet
Beeping on startup
1. did you have this problem before? Is this why your were replacing memory? Usually, the beeps indicate that your memory is fine. *********** board- for the most part is fine- This sounds like A Video problem- either a lose card, plug, cord, or bad slot.
2. What is the color of the light on your video monitor?
Check and make sure that you did not unplug or losen the video card. Check all the plugs and wires on all connections both inside and outside the computer. Make sure the monitor is plugged in both the back of the computer and the back of the monitor.
Mar 27, 2009 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Computer turns on and beeps.
I suggest you check you memory sticks, and make sure they are seated properly. The long beep usually signifies a memory problem. If you have 2 memory sticks, I suggest removing 1 of them, then tuen on the PC, if it still beeps, powerdown by holding the power button in until it shuts down, then replace the removed one, and remove the other, if it boots, fine, then you will need to replace the memory that you have removed, but,,,,,if you only have 1 memory stick, I suggest you replace it, if the pc still beeps a long beep, then 1 of the memory sockets is bad, and a motherboard replacement is needed, either case, that long beep is a memory problem.
Jun 17, 2007 | Dell OptiPlex GX260 PC Desktop
eMachines W4685  PC Desktop Logo
59 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
