Question about Whirlpool Refrigerators
Slow dripping water from top freezer into the main fridge
We have a 1997 whirlpool fridge and it slowly leaks water from the roof of the main fridge onto the top tray it takes about 3 days for alot of water collects
We just got rid of our 26 year old Kenmore for this reason. In 26 years I used a hair dryer to thaw out a tube toward the back of the refrigerator. At least in ours when the tube gets frozen shut the water had nowhere to go but in our egg tray.
Posted on Oct 23, 2008
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
The top freezer is frosting up. While looking inside the main fridge, in the back there are two square openings. One is dripping water, the other frosted up. In the back of the freezer there appears to be...
drain tube froze up also not allowing water to drain into the bottom drip tube but ur problem is that the fridge didnt automatically defrost so what i would do is call the place where u purchased it and get them to check it out cause it should still b under warranty
Jan 24, 2011 | Whirlpool ET1MHKXM Top Freezer...
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking freezer into fridge
Hi, What has happened is that the drain hole in the freezer has frozen up and the defrost water is dripping into the fresh food area.
Remove the floor panel and the rear fan cover in the freezer and you see the ice that is blocking the drain.
Be carefull when removing the ice. DO NOT use a sharp object. The best way is to use a hair dryer.
Once you locate the drain hole, you will need to melt the ice down in the drain hole too. For this, you can use the hair dryer or poor a few glasses of hot water (sopping up the water between each glass).
What you will need to do after the drain is open is to put an after market drain heat transfer kit on to prevent this from reaccuring.
Please let me know if this is the case and I can get you the right part# or even send you the part.
May 14, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
Refrigerators Logo
157 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
