Acer aspire x1430g
Boots into safe mode
SOURCE: Acer Aspire T650 PC
PROBLEM RESOLVED
I contacted Acer and I was told in order to eliminate a software problem I should carry out a Disk2Disk recovery. I tried this and the problem was solved. No cd's were required, all I had to do was press ALT and F10 when the machine is switched on. This takes you to the recovery part. The machine than recovers to factory settings. Carry out the necessary updates and Bob's your uncle!
My thanks to Kevin and the rest of the team.
FixYa! is cool
Posted on Mar 21, 2008
  • 95 Answers
SOURCE: acer aspire 6920 two weeks
Your keyboard cable is probable bad and your vga cable is probable not sending any signal to your monitor
Posted on Sep 14, 2008
budhoyo
  • 26 Answers
SOURCE: Recovery restore disk does not
ok, don't worry, check your bios setup, place first boot device is cd/dvd, save your configured bios and out from bios setup.Ok insert your Recovery disk and restart your acer. Push any keyboard tuts if Any Question to boot via cd in boot process. Ok follow step by step discription in process recovery.  If you don't know how to inside bios setup, if you reseting acer look first process boot you will saw what's keyboard button you must push, ok good try, and don't forget to vote me, Thank's
Posted on Nov 03, 2008
sacraty
  • 64 Answers
SOURCE: Acer aspire one not booting
your laptop has been turned off without shutting down. all your laptops registries are probably messed up. the easiest way to do is to reformat your computer or restore it to factory settings. unless you have some important files that you cant afford to lose.
Posted on Feb 07, 2009
leecom72
  • 4806 Answers
SOURCE: Acer -Video Display Issue
Hi there.
This could be 1 of 2 problems, lets start with the first.
#1 Bad display drivers
Boot the laptop into safe ( i am assuming you know how to do this by your post ) on the computer icon, right click and select manage, a new window will pop up and then select device manager, the list will populate with hardware that installed on the PC, look down the list for display adapters and click on the + sign on the left hand side to open the tree, then right click on the display adapter and select uninstall. Now restart the laptop and let it boot up as normal, if the display drivers were bad it will boot with the screen resolution as large, once you log in it should auto detect the display and install the drivers (you may have give it permission) if this works then that was the problem.
#2 Faulty graphics card.
Take advantage of the manufacturers warranty and send it in for repair as there will be nothing you can do about this kind of hardware failure.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
Posted on May 19, 2009
Acer laptop stuck on Windows boot manager
1. Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time.
2. During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup."
3. Keep pressing the "F8" key until the "Advanced Boot Options" menu appears.
If you receive a "keyboard error," restart the Acer Aspire and repeat step 2.
4. Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu.
The arrow keys are located on the right-hand side of the Acer Aspire keyboard.
5. Press the "Enter" key to execute the "Safe Mode" selection.
The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again.
May 25, 2013 | Acer Aspire 5742Z-4601 : 2GHz Pentium...
How do I get into safemode on my acer aspire desktop
1 Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time. 2 During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup." 3 Keep pressing the "F8" key until the "Advanced Boot Options" menu appears. If you receive a "keyboard error," restart the Acer Aspire and repeat step 2. 4 Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu. The arrow keys are located on the right-hand side of the Acer Aspire keyboard. 5 Press the "Enter" key to execute the "Safe Mode" selection. The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again. Read more: How to Boot Up Acer Aspire in Safe Mode ' eHow.com http://www.ehow.com/how_5802430_boot-acer-aspire-safe-mode.html#ixzz1dtOxfxaD
Nov 16, 2011 | Acer Aspire Computers & Internet
Acer aspire 7741Z-5731 won't boot past windows screen
Corrupted windows installation. If you can boot to safe mode, run a disc check and see if that resolves the issue, If it does not, or you cannot access it in safe mode, you need to repair your version of windows with the install disc.
Mar 27, 2011 | Acer Aspire 3000 Notebook
How to reset my ASPIRE 5534 Series laptop do to
I can't get my Acer Aspire 5534 to play movies on DVD
Jan 06, 2010 | Acer Aspire One PC Notebook
My acer aspire 3000 can not finish booting
you must try to open your system in safe mode
to start your system in safe mode
pressF8 when the BIOS screen appear
from there you are able to find the application causing trouble in startup.
you cane also try system restore in safe mode
for system restore take help of windows help and support
Apr 23, 2009 | Acer Aspire 3000 Notebook
Starting in safe mode will not restore - - - help
In the safe mode try the option last known good configuration..
Apr 21, 2009 | Acer ASPIRE 5720-4649 Notebook
Insert your Windows CD and boot up laptop and select install Windows (not the Repair at this stage) continue until you get another option to Repair system.
Apr 12, 2009 | Acer Aspire 3680 Laptop
Acer aspire
If it keeps booting in the safe mode, at the desktop it will say SAFE MODE in each corner of the screen.
If it does boot to the safe mode, click start, RUN, MSCONFIG click OK
Click the Boot.ini tab,. and see if the /SAFEBOOT option is checked.
If the screen doesn't say safe mode, then your video resolution is set too low, and adjusting Display properties and or reinstalling the video driver should resolve.
Jun 14, 2008 | Acer Aspire 9300 Notebook
My Acer aspire 5100
If you are able, when the pc is booting up keep pressing F8, this will take you to safe mode and not allow the graphics driver to run. When in the safe mode options, select either Last known good configuration or start windows in safe mode. Last known good configuration should find the last good system settings, when it reboots. Start windows in safe mode allows you to go into windows using the administartor account, and then you should select system restore and restore back to the day before or just before you updated the graphics driver.
Aug 16, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
