Question about Acer Aspire One A150-1006 Notebook
My Acer Aspire A150 turns on but the screen is so dim you can barely see anything. the battery is full! please help!
  • 43 Answers
Sorry but if you have dim screen is because the lcd panel need to be replace , make sure the new panel comes with the ballast , the lcd has a lamp between the screen the life of the screen is over that way look like that
Posted on Feb 08, 2012
5 Suggested Answers
  • 162 Answers
SOURCE: my acer aspire 9300 screen is so dim i can barely see anything
Hi.
      Have you tried adjusting the Brightness of the Display? May seem like a stupid thing to ask, but some laptops come with what is known as Ambient Light Sensors and by setting a higher brightness level it Disables the Ambient Light Sensor kicking in.
Posted on Dec 03, 2008
  • 162 Answers
Try resetting the laptop to default settings in the BIOS. If that don't work, sounds like there's a problem with the backlight in the LCD Display.
Most laptops come with Ambient Light Sensors, that can adjust the display based on the lighting in the room.
SOURCE: Just bought a Acer Aspire ONE A150-Ab today. It
If there less than one year take it to a Acer service center or where you bought it and have replace.
Posted on Jul 08, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Acer Aspire One A150 : screen all dark after changing it
It is an inverter problem. Check all cable attachments first, then change out the inverter.
Posted on Apr 23, 2010
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Dim lighting
You need to configure the power options.
Go to control panel and then click on power options.
Select advanced power options and there select the power mode as balanced or high performance.
Jul 20, 2010 | Acer Aspire 5100 Notebook
Cracked screen
http://cgi.ebay.com/ACER-ASPIRE-ONE-8-9-LCD-SCREEN-ZG5-A150-AOA150-AOA110_W0QQitemZ180422161297QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2a01ffb391
you do not need to replace the converter- As long as your screen is just cracked then the converter is fine. Converter may be bad if your screen is really dim or just blank.
Mar 22, 2010 | Acer Aspire 5100 Notebook
Feb 17, 2010 | Acer Aspire One A150-1049 Notebook
My son (9 yrs)has an Acer Aspire One and for some reason it will no longer turn on, even after a full charge. My daughter (11 yrs) had a similar problem and it cost me $150 to fix. According to technician...
Try removing the battery and connect the power cable and try turning it on. If that does not work hold the power button down for about 10 seconds(with battery out) to remove left over power(flush). put battery back on and try to turn on. if it still does not work, there may be a harware issue and you may need to take it in for service. And by the way, if it turns on with the power cable connected and no battery, then the battery may be faulty.
Feb 08, 2010 | Acer Aspire One A150-1006 Notebook
Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 08, 2009 | Acer Aspire One A150-1006 Notebook
Just bought a Acer Aspire ONE A150-Ab today. It worked 1st power on. Now just a blank screen and nothing else
My acer aspire 9300 screen is so dim i can barely see anything
Hi.
Dec 03, 2008 | Acer Aspire 9300 Notebook
Acer Aspire One A150-1006 Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
