Question about Sony Playstation 3 (PS3) Console
Ps3 wont turn off just makes 2beeps when i press the power off
  • 43 Answers
Would has to open the unit and check for bad power supply , if the power supply is ok ( no bad capacitor ) the problem would be the main pcb or the hard drive
Posted on Feb 08, 2012
PS3 error 2beeps and blinking red light
hi there,
it sounds like its a common problem you have with the ps3, its hard drive related, luckily if that's all it is there is an easy fix. once it's not a flashing yellow light known as (YLOD, yellow light of death) then it should be a simple matter of just removing the HDD and re inserting it again. Find below some youtube videos on the cause and how to fix it. Hope this helps
Jul 29, 2014 | Sony Playstation 3 (PS3) Console
Ps3 won't work, screen says restore software
take out ur harddrive, turn ps3 on wit no hardrive den put it back in and turn on again,
if this dosent work hold power button and eject button on front of ps3, 1st u will hear 1 beep then 2beeps ,wen u hear 2 leave go,
it will say connect controller with usb, do that and u will get 6 options,
pick option 3,but if that dosnt work pick option 6 ,but option 6 will delete all ur saved data so be warned.
Nov 24, 2012 | Sony Playstation 3 (PS3) Console
I have a insignia lcd color tv & dvd player & the hdmi port wont let me play my PS3 system
If your sure the PS3 is not the problem. You can try uplugging the television for about 5 minutes or so and plugging back in. With the PS3 hdmi hooked up to tv turn on tv. IF it still doesnot recognize then you either have a faulty main board on the television or a problem in the PS3.
You can reset the PS3 to make sure its not causing the problem.
With the PS3 turned off, press and hold the power button until you hear 2 quick beeps then release and press power again. This will reset the PS3. You will not lose any stored information doing this!.
Hope it works!!!
Jun 08, 2011 | Televison & Video
I turned on my ps3 and nothing is happening it is not giving me the option to sign in or anything. just the blue backround nothing else and now it wont let me turn it off.
Sounds like you PS3 software has become corrupt. Follow these steps to sort it but I must warn you, you will lose all your save games!!
Step 1. Turn the PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later then beep once more and turn off. Release the power button when it turns off.
Step 3. Press and hold the power button again. It will beep as soon as you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. As soon as you hear the two beeps let go of the power button.
Step 4. Your PS3 will now boot into recovery mode. Connect you controller via USB when asked and press the PS button.
Step 5. Select option 5 from the recovery menu, "Restore PS3 system". This will rewrite your PS3 software and hopefully should sort your problem.
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 wont read any discs, films, games, or music. The machine just stopped whilst playing a dvd and now refuses to work
Dear,
you may try to use the PS3 recovery options.
The PS3 stores a copy of firmware drivers on the hard-drive and will reload any corrupt files. To access the recovery menu, do this:
  1. Make sure the PS3 is turned off
  2. Press and hold the power button on the PS3 it will power on then power off.
  3. When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
  4. It will ask for the controller to be connected via the USB cable,
  5. Turn on the controller and you will have access to the menu.
Be aware that you may lose all your data previously saved. Good luck, Peter
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont eject a movie, tried turning it off and on, the blue light doesnt come on either, how do i get it to eject the disk
switch off ps3, right now before turning on the ps3 keep your hand pressed firmly down on the eject button and the on/off button simultainisly and then power up, it will make a loud fan noise but the game/dvd will pop out.
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
My ps3 won't play discs
this has happen to me!! and i end up buying another ps3 and it end up the same!!! i fix both of them!!! and about over 200 consols with the same problem!!! this is what u do! you connect your control direct to your ps3. and then you hold the power button for 5 seconds!! the system will turn on!!!remove your finger for a second and hold the power button till you hear 2beeps then remove your finger and the system will shut off!! this is a manuel reset!!! the system will turn back on!! asking u to connect your controller!! you already have it connected. then it will give you about 6 options!! you will choose RESTORE FILES!!! your system will check for your system defaults!! then it will tell you that you have corrupted files!! and proceed with it!!! it will fix if you have problems with your controls,if it doesnt play games,blue ray,if it freeze, system shutting off,icon problems,only playing sertting games or movies!!! if you have problems or any question feel free to ask!! i know is fustrating!!!
Nov 04, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont turn on using controller and power button...
try cycling the power on the back of the console
are the lights blinking on your controller when you press them?
Jul 11, 2009 | Sony Playstation 3 (PS3) Console
My ps3 power wont turn on at all? i hit the switch but???
man i dont know what to tell you but to change your hard drive and and or get a new ps3 dude
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
