Question about Dryers
Frigidaire stacked washer/dryer: Dryer won't turn off on automatic cycle
I own a Frigidaire stacked washer/dryer, model LCE702ADD2. The dryer won't turn off on automatic cycle (timed dry cycle works fine). Already replaced the timer and didn't solve the problems
4 Suggested Answers
SOURCE: Stacking Instructions
Hello Marianne  i don t know if you ve found the answer on how to stack the washer and dryer but here it go, i was looking for that as well on the net and no such instruction, i had the print instructions that i found  hope it ll be helpfull
Posted on Jan 01, 2008
  • 4 Answers
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Posted on May 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: My dryer works but no heat
On the backside near the bottom of the element is a limit that has 3 wires. The smaller wire goes up to the timer and it powers up the timer motor in the auto cycle. On the blower housing is a cycling thermistat with 4 wires.(2 small and 2 big wires) The 2 smaller wires are connected to a tiny heater in the cycle thermistat. To get from cotton to permapress we simply heat up the little old heater and the cycle thermistat shuts down faster. Clever heh? Where wuz I? OK: While the heater is fired up the timer motor will not move. When the heater stops working the timer moves forward. So as the clothes get dryer, the heater comes on less and less and the timer motor gets more and more power till finally the heater is no longer is needed. Then the timer goes on over to the end. Pretty dang clever ain't it? Well what can go wrong? The cycling thermistat is causing the limit to control the heat( you would know because the clothes would be all hot and wrinkly) OR the vent to outside is clogged. As a result the smaller Hi limit atop the heater chamber is blown. a Replace the control thermistat AND that 3 wire limit on the bottom of the heaterlong with it's very blown little cousin atop the heater chamber.. Oh yeah. Remove the vent pipe and get the gunk out:
SEE THE PICTORAL
Posted on Jul 07, 2009
Turn off buzzer on frigidaire dryer LGR331SO
Good Afternoon Friend,
I understand that you want to turn the buzzer off of your Frigidaire dryer, model# LGR331SO. With your model dryer, you are not able to turn the buzzer off. I hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
Dryer stopping mid cycle
You have to test several parts, common causes are defective termic sensor, or fault program control.
Post model number for more details
Jun 01, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer / Dryer dryer won't start
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and start normal cycle. If this proves to be ineffective, then contact a professional to move forward accurately. Possible causes could be a faulty power cord or house wiring, defective control board, thermal limiter or door switch.
Oct 22, 2012 | Frigidaire FEX831CS Top Load Stacked...
Stacking Frigidaire Washer Dryers
no you do not need to put them on rollers. yes it would make it easier to service them but rollers would not be stable enough to keep the washr from shaking in spin cycle.
Jan 23, 2009 | Frigidaire Washing Machines
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dryers Logo
192 people viewed this question
Top Dryers Experts
