Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
New carburator doesn't passed fuel
Hey friends I have a 17" craftman weedeater, and replaced the carburator the book manuel just change the way the carburator works. The vaccum adjustment are not there and all that need is the idle adjustment. But, the new carburator doesn't passed gas. Can anyone help.
  • 50 Answers
Are you sure that that the replacement is the correct one. Also, why did you have to replace the carburetor . Did you verify that the carburetor was the problem? Did the weedeater run by priming? Did you check the pump and lines? If these methods were tried and did not reveal the problem, then I suggest that you get professional help.
Posted on Jan 03, 2009
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
When my bakkie gets hot then the petrol doesn't go through the carburator
Test your fuel system for VOLUMETRIC FLOW. Measured amount of fuel for x amount of time. Not sure what the spec is, but what happens is a filter in the tank clogs and restricts flow (I assume you have replaced the fuel filter...).
So the system often can pass the fuel pressure test, but not the volume test.... It is easy to observe.
Jan 16, 2013 | 2007 Nissan 1400 Bakkie
Replaced the fuel line on my WEEDEATER GTI 17 XP grass trimmer. Having trouble bleeding the fuel line. Is there a poecial technique? I filled the gas tank and let the gas flow through the line until I...
The fuel line is self bleeding, if there is a lot of air in the pipe there must be a hole in the pipe or the filter is not completlt submerged in the fuel.
Aug 01, 2011 | Garden
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a Troybilt weedeater that works great until I put the tiller attachment on. With the tiller on, it dies after a few minutes of use. Any ideas?
Hello dane. Change the fuel filter, install a new spark plug and a new air filter. Then get a can of carburator cleaner to add to your fuel. let that treated fuel run for 5 minutes and you should have your problem solved. If not, you will have to replace the carburator or rebuild it.
Joe
Thanks for choosing Fixya!
Mar 21, 2011 | Troy Garden
I just put new fuel line on my trimmer now i cant start it not getting fuel the line never fills with fuel but i can **** fuel out so i know it not pinched it a weedeater brand ght-17
Make sure the little valve under the tank if you have one is fully turned clockwise. Make sure there is nothing clogging the tiny screen inside the fuel tank. Check or test your primer bulb it may be leaky. If carb or intake is leaking, you won't get gas either. If you have a filter on this model, try changing it.
Sep 10, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
How to replace gas lines on a Weedeater Excaliber Hedge Trimmer
My Bolens Weedeater runs for 3 or 4 seconds and stop but it will run only if I drop some gas in the caburator then stop. Can you help me with this problem?
Norris.
Sep 25, 2009 | Garden
Weedeater will not start
For a weedeater that only runs when you prime or inject fuel manually the easiest thing to try first is replacement of the fuel filter. I have had this happen several times over the years and other than a broken or cracked fuel line the filter usually is the problem. If this does not work, then work on the carburator may be needed, but the filter is an easy common problem.
Sep 01, 2009 | Garden
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
229 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Roland W VanLue
Roland W VanLue
EugenesDIYDen
EugenesDIYDen
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
