Question about Garden
Have a 3235 cub cudet tractar mower hydrastatic when you leave the clutch out the tractor jumps up and down after it gets mowing it's ok till you push clutch in then same thing
It just jumps and shakes you in the seat till you get going when you let clutch out after you get mowing it is ok till yuou stop thren same thing
  • zakame19
    zakame19 Feb 09, 2012
    it's about 5 yr old always mowed good just started this
  • Jeff Caskey Feb 09, 2012
    The PTO clutch pulley may be bent or loose.
  • 20 Answers
Not knowing how old the unit is or how long it has been since last fluid changes sounds as if the fluid filter may be clogged. Could also be be pinched fluid lines. Chk here for parts http://www.partstree.com/parts/?lc=cub_cadet&mn=3235+Tractor+S%2FN+1K010G+%26+After and or reference materials.
Posted on Feb 08, 2012
Why would my belt on my cub cadet 1046 mower keep popping off?
Did you put all the belt keepers back on? I find a lot of DIYers usually leave one off thinking it is not important.
Jun 30, 2015 | Cub Cadet Garden
Have a 3235 cub when blade engagement is pulled the blades don't always engage. Several attempts and the blades will engage. Switch or the clutch?
check the contacts most times the clutch contacts are loaded with grease and grass residue , simply cleaning the contacts should fix the problem
Sep 30, 2014 | Cub Cadet Garden
Rider will not turn over more than once no matter how many times I try.
I sounds like there's significant resistance to the engine turning over. I experienced this when the electric PTO/clutch seized - and the mower was trying to turn over the engine AND the mower blades because the PTO wasn't disengaging. Try taking the mower belt off the PTO and see how the engine turns over. If it's still slow, the problem is in the engine. If it spins normally, replace the PTO clutch. BTW - when my clutch seized, it also burned out the PTO switch. The switch is pretty inexpensive, so if you're replacing the PTO/clutch (I found one online for about $175.00 - MUCH more expensive at the dealership) - you should probably replace the switch as well.
Jun 28, 2014 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cudet 31p7770299e1 briggs stratton engine
check and see if intake valve seat is loose as motor gets hotter condition worsens
Apr 23, 2013 | Cub Cadet Garden
I have a cub cadet 1000, it's approx 4 years old, i was in the middle of cutting the grass and the mower stopped running. Tractor runs mower will not come on. Is there a switch or module that nee
check the clutch on the end of engine drive shaft it is the same as a car air con clutch put power on to it and it should click so most likely the wire from switch to clutch
Apr 22, 2013 | Cub Cadet Garden
My cub cadet 2165 PTO clutch has no voltage getting to it to activate it. the normally closed switch is ok. could it be the relay? how do I test it?
on my cub the blades keep shutting down when im mowing . I replace the pto switch and it doesnt help .. got a recommendation
Feb 03, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
HYDRASTATIC TRANSMISSION DOESN'T MOVE
Far as I know the warranties are not transferable. Some hydrastatic transmission fluid can be checked by removing the battery and underneath there is a place to put the fluid and to check it. But not all models or makes gives you this option.
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
