Question about Dell UltraSharp 1905FP 19" LCD Monitor
Monitor revives only after cycling the power many times
At boot-up, the black light of the monitor appeared to come on and the LED power light is green. No images would be displayed and the front panel controls would be frozen. I unplugged and plugged in and then the monitor functioned as normal. The problem got worse. I had to unplug and plug in several times before the monitor would function normally. Later, I discovered that I could unplug the monitor from the PC and allow the test pattern to float about the screen for several minutes before reconnecting. This procedured seemed to substitute for the cycling of the power, i.e., after serveral minutes of the test pattern, I could connect the monitor to the PC and it would function normally. The problem is getting much worse. Instead of a few minutes of the test pattern, I now must leave the test pattern on the screen for hours before reconnecting. If I am premature, the front panel freezes and the screen is blank, although it appears to be back lit. I have tested the monitor on another PC and it manifests the same problem. By cycling the power, or by using the test pattern, an image is displayed on the screen. It seems this must happen to "warm up" the monitor in some way. Some threshhold is crossed and then the monitor can opperate perfectly normally. What's wrong and how do I fix? Thanks.
  • Rbeau Apr 23, 2008
    I have a very similar problem: Monitor worked fine .. flawless for over two years. Then last week would not sync up with my laptop. If I booted the laptop separately, and then plug the monitor in...after a period of time it would finally sync and then worked fine again. Each day it has been taking longer for this to happen .. and now it doesn't sync at all. If I leave the two connected and the laptop goes into sleep mode, the screen comes back for me to log in on the laptop, but then both screens are black .. and I cannot do anything other than a hard shut down.
    Any ideas out there?
    Thanks!
Unscrew 4 screws on the back side. Place the monitor with the front up and open it along the upper seam. Turn it again and lift the back cover. Shift the inner case "up" and take the button holding plate out - it is being held only by a tape. Inspect it and clean it. You might have to replace the condensers and/or switches on it.
This might solve the problem, but there may be other causes as well.
Posted on Feb 24, 2009
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
When i turn it on it only appears only a second , my monitor turn black
Hello Chelleydiao, hi, its either you have a CPU problem or the monitor itself. Check or use another monitor to see if the problem is fix. you see an blank monitor can also be caused by the CPU if it fails to boot. the aid the checking, do you see any orange light on the monitor? or any indication.... the led light on the screen in summary: green or blue means there is power and the CPU boots up. if orange the CPU fails to boot, if there are no lights on the Monitor panels, there are problems on the monitor. check these first....I need a much detail description.
Dec 18, 2010 | AOC Monitor
The system boots normally but does not display on the monitor, what is the way forward
If it boots normally and there is no display on the monitor,it could be
1.Your Display card could have failed or the VGA cable from the display adapter is not connected properly to your monitor- In this case you will see a "no signal" message on your monitor.
2.If the monitor is powered on nothing appears,then your monitor most likely failed.
3.If the monitor's power on led light is not lit,then make sure your monitor is plugged in properly to the power source.
Oct 27, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Monitor to black, power LED blinks, hard re-boot and it works
Take a look at your power saving settings. It sounds like the monitor is set to sleep after 20 or 30 minutes. You may want to change your setting to "never". The settings are under Control Panel - Power management
Aug 15, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
The monitor turns black immediately after power cycle
i think it can be the capacitor problem, open monitor an look for swollen capacitors. if you will find them swollen or mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:IT;} @page Section1 {size:8.5in 11.0in; margin:56.7pt 42.5pt 56.7pt 85.05pt; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} loosing the electrolyte, signs of burn, change them
Apr 12, 2009 | LG 22" FLATRON LCD Monitor
I have a black screen when computer is booted up.
Check in the back that all cables are connected
Check your power supply
Check your memory
Check your video card
Nov 12, 2008 | Hanns.G Corporation HX191DP LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Dell UltraSharp 1905FP 19" LCD Monitor Logo
211 people viewed this question
Clive
Clive
Alun Cox
