Question about Dryers
Replace a drum belt Kenmore Elite model 11067062600
docjohn174
  • 943 Answers
SOURCE: drum belt broke
http://www.applianceaid.com/slidewpdry.html Hi here is a step by step way of replacing the belt
Posted on Dec 23, 2008
lojacksdad
  • 121 Answers
SOURCE: dryer does not heat, drum does rotate
check the tstats on the heat can
Posted on Apr 23, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: I need Directions how to replace the belt.
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......
Posted on May 05, 2009
  • 11 Answers
SOURCE: no tension on the tension pulley.
Check that the slide/rod /bracket is not jammed on the adjusting mechanism.
Posted on Jan 18, 2010
kel1guy2002
  • 3740 Answers
SOURCE: belt routing
Go to figure 11 of this link:
http://repair2000.com/wpoolbelt.htm
Posted on Mar 06, 2010
Testimonial: "awesome! Thank you!"
All power is good, heats up but drum won't turn. Hear humming noise after pushing start button. Relaced motor,thermal fuse and thermistor. Still nothing. Checked door switch. Any other suggestions?
Betty,
When you replaced the motor, did you also replace the belt? If you had not said that you already replaced the motor, I would have suggested that the belt was broken.
Jun 09, 2015 | Kenmore Dryers
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What do we do to address thumping noise in Kenmore Elite HE4 Dryer?
It is probably one of the idler wheels it rotates on. Look for a flat spot and if you didn't replace the drum your self ask for your money back.
Dec 11, 2014 | Kenmore Elite HE4 Electric Dryer
Replacing dryer drum Kenmore Elite Electric Dryer
Usually from the front. Lift top and remove front. I can't image it would be worth replacing the drum. What is wrong with the drum? or do you mean the belt to drive the drum.
Jul 25, 2010 | Kenmore Dryers
Loud squeal on Kenmore Elite HE4 model 11095872402. Need to replace drum bearing or other?
you need a new belt and a roller for the belt tensioner
Sears sells these as a set
Jun 06, 2010 | Kenmore 97561 Gas Dryer
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
No tension on the tension pulley.
Jan 18, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he3 model # 11044832200 gives me a f15 error code. have already unplugged and replugged every connection between the CCU, MCU and drive motor, machine will fill and drain properly but will...
it because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Driver Belt
just remove back cover ..install belt on small motor pulley first then work around drum pulley while turning large pulley try spinning by hand first to verify belt is tracking in center or close to center of large pulley
Jul 22, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
