Question about Shimano Cycling
R3013WM I need gear cassette
This error code indicates a problem related to paper cassette lift mechanism. First thing that you will need to check is, if the printer makes some strange noises at initialization, when the printer is trying to lift the paper inside cassette. You can verify if the lift mechanism on the printer is ok, by removing paper cassette and press the 3 small white switches on the left of printer. At this moment the printer is trying to lift the cassette and you will see a gear that rotates on the right side of printer. Also verify if the GEAR LIFT Z64 is intact by opening the gearbox(the big one from the gears from the right side of paper cassette). This gear is cracked in most cases. Replace it.
May 06, 2014 | Kyocera FS-4000DN Laser Printer
Skipping when applying pressure to pedals
needs a gear adjustment hopefully. it might have a stretched chain along with worn cassette teeth. if you have ridden alot of miles in the smaller gears in the rear you might have worn them out. you would have to replace chain and rear sprockets/cassette
Dec 09, 2012 | Trek 4300 Disc
How do i remove rear gear cluster from giant rapid three cycle
Proper tools are a necessity. A cassette lockring tool and chain-whip (examples: http://www.roadragecycling.com/2012/10/bike-tools-top-11-you-need-most.html about half way down the page)
The proper lock ring for a Shimano 9 cassette is a Park Tool FR-5. There are other generic tools as well; but the FR-5 is the most common.
Many companies make chain whips too. My favorite (and the one in the picture) is the Wheels Manufacturing tool. It is also one of the most affordable.
For what it's worth: if there is a bike shop near you - many will remove a cassette for a nominal fee. Often $5-10.
Oct 08, 2012 | Shimano 9-Speed Bike Gear Cassette
How do you get the gear sprocket off the back tire of a mongoose crossway 450 bicycle
To remove any rear freewheel or cassette you will need to purchase a Park Tool. Park Tool is the best brand when it comes to bike repair. Google Park Tool and you can look through their products. You will need a cassette/freewheel remover. There are dozens of different companies that make hubs and cassettes (gear sprocket). Take a look at yours and see what company made it. You can than find out which tool with properly fit your cassette. These tools are made to fit in a wrench making hand removal easy. Some brands will require a chain whip. The only way you will know which too you need is by find the company name on the cassette/hub. Without this tool removal is virtually impossible. If you need help narrowing down which cassette remover you need you can always let me know the company name and I will let you know the proper cassette tool to purchase.
Oct 31, 2011 | Mongoose Exile 26 Men's Full-Suspension...
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
I can not pedal back and the angle of the lower section is at a 45 degree angle more or less
Make sure your rear derailleur is lined up with one of the rings of teeth on your rear gears( cassette ). Also make sure Your chain is riding correctly on one of the front gears on your crank. If you are still unable to back pedal make sure that one of the cogs (gears) in the rear derailleur arm isn't seized. They must both be able to rotate and the chain should pass through them in a backward S pattern. If you still can't back pedal remove the back wheel or move the chain off the cassette to see if the cassette will freewheel. It has to move freely in a counterclockwise direction in order for you to backpedal. Moving in a clockwise direction engages pawls inside the cassette which lock it into a drive situation which propels the bike. If the cassette will not freewheel in a counterclockwise direction you will need to take the rear wheel to a good bicycle shop to have the cassette replaced. It requires a special tool to remove it. Hope this helps.
Aug 06, 2009 | Shimano 09 Xtr M971lc Mountain Bike Rear...
Bmw casette
Hello.
You need to take out the cassette deck from the car. open the cassette deck by removing the various screws, once open, there is a small plastic gear which you need to wind manually which will slowly release the cassette.
Oct 26, 2008 | 1999 BMW 323 Series
I have an old Video Camera, Sanyo VM-RZ2R 8mm camcorder. I can't get the cassette holder to eject. There's no cassette in it at the moment but when I press the eject button, the camcorder turns a couple of...
Your eject problem will be one of three things. 1- the gears for the eject mechanism have shifted and not making contact with each other. You can fix this by realigning the gears. 2- The gears are stripped and need replaced. 3- there is a small plastic pin that releases the cassette bay. check to see if this pin is broken. If so, then you will need to replace the pin or the gear the pin is attached to. With this being an older model, parts will be extremely hard to find. Let's hope that the gears are just misaligned.
Aug 05, 2008 | Sanyo Cameras
Stuck tape
If you haven't already done so, don't get overly forceful to avoid bending or breaking something. Often the cassette carriage mechanism is gear driven, and by moving the gear one direction or the other will unload the tape. You may need to disassemble the machine further to gain access to the drive mechanisim. Sometimes the carriage mech. can be entirely removed from the VCR by removing the attachment screws. Other times, these screws are made inaccessible by the tape itself. Look down on the right side of the carriage. If you do remove the carriage, mark the gear positioning first! as the gears must be positioned back exactly as they were from the manufacturer. You might need to employ the services of a technician if things are complicated.
May 26, 2007 | Panasonic AG-DV2000 Mini DV VCR
Cycling Logo
42 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
