Question about Makita Saws
Blade replacement assembly for Makita ls1011
Safety guard assemly
  • 271 Answers
SOURCE: how do you ulock the saw to pull up the blade so you can put the wood underneath to cut
push down gently on the arm and reach around to the rear of saw with your right hand and pull retainer pin the arm should release and allow usuage of your saw.
Posted on Oct 24, 2008
danny_murray
  • 55 Answers
SOURCE: I need a owners manual for my makita LS1011
Here this should help out
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=370
Posted on Dec 05, 2008
CDNMoose
  • 15 Answers
SOURCE: Blade guard spring assembly for LS1011
here ya go Bob hope it helps
http://www.ereplacementparts.com/makita-ls1030n-miter-saw-parts-c-97_98_99_321.html
Posted on Feb 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: I just acquired an LS1011 Makita saw. How does
unscrew the handle in the front to change, also I would recommend going to Makitatools.com and typing on your model number to download a users manual for this tool, it would be helpful to get the most out of it.
Posted on Oct 25, 2009
  • 157 Answers
SOURCE: how to replace saw blade and re assemble the blade
Hello. The guard does not have to be taken apart when changing the blade. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Posted on Apr 05, 2011
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
May 01, 2011 | Makita 10" Miter Saw LS1030N
How to replace saw blade and re assemble the blade guard
Oct 10, 2010 | Makita 10" Miter Saw LS1030N
The spring for the blade cover has come off how do you fix it? my dad has given me his saw to fix the spring that brings the blade safety cover around, how do you fix it the the mounting post. When I do...
if it a Makita saw it will rub on the guard slightly, What is the model number or you can go to Makitatools.com and type in your model number to see a breakdown for this tool. The post is on the back side of the upper guard and there is a hole in the guard itself for the other end.
Oct 03, 2009 | Makita Saws
Jan 01, 2009 | Makita 10" Miter Saw LS1030N
How do you ulock the saw to pull up the blade so you can put the wood underneath to cut
Oct 08, 2008 | Makita 10" Miter Saw LS1030N
Saws Logo
218 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
