Question about Reebok Exercise & Fitness
I have a Reebok RT100 , will no longer run on load
I have a Reebok RT100 ,it started to get hot on the right, over what looks like a coil and started to smell,then cut out. It will now only run with no load, advice please.
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: reebok i run stuck on full speed smells of burning
1) LUBE THE DECK BELT,this produce enough friction for shut down.
2) test the drive belt and replace it. if is necessary.
3) Test the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) See any wires is loose, and tight 6)See if there som animal inside that bit some wires.!
6) Run the software calibration for diagnose, and troubleshooting, and fix it.
sincerely. God bless you
Posted on May 07, 2012
Reebok T3.2 treadmill stop after couple of minutes
7 amps wth no load is kind of high for this.. be looking at the surface that the belt is on.. and the rollers for excess drag..this should completely freewheel when no one is on it..
Jan 19, 2014 | Reebok Exercise & Fitness
Reebok tr2 incline wont work, back of machine starts to rise when you prees the incline up button
1) lube the motor elevation, shaft +gear and adjust the POTentiometer a little
2) see the diagram attached,
3) Run the software calibration for troubleshooting,
4)test the relais for open or faulty coil,and clean the contacts very well
God bless you1_22_2013_5_10_05_pm.gif1_22_2013_5_10_34_pm.jpg1_22_2013_5_11_02_pm.png
Jan 22, 2013 | Treadmill Doctor Reebok S 9.80 Treadmill...
Need to know torque specs for clutch springs on a 1993 rt100 yamaha
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1990 2000 YAMAHA RT100 Service Manual Repair Manuals AND Owners Manual... $10 cheap
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-rt-owners-manuals
Yamaha RT100 Specs eHow
https://en.wikipedia.org/wiki/Yamaha_RT180
Apr 28, 2012 | Yamaha Motorcycles
My 01 alero will start fine amd run a little bit thrn sputters and dies. Will restart right away but the longer it sits the longer it runs. New ign coils wires plugs amd fuel press. regulator, is it the...
i would look into the idle air controll valve it controlls the idle on your car and since it starts a shuts off does it idle a little low when you start it then just stall out and shut off
Jun 11, 2011 | Oldsmobile Alero Cars & Trucks
Google: Randall Padilla, that's me.
What could be an issue is if the cabinet is a 4 ohm cabinet and you plug it into the 8 ohm output. of the RT100 ... IT WILL BE LOUDER that way... for a LITTLE while... till the power tubes get gassy from overheating and the sound will GO AWAY. VERIFY the impedance of the cabinet and plug into the correct jack on the RT100. Every RT100 will do this... it is GROSS abuse of the amp if you plug 4 ohm speakers into the 8 ohm jack. Some of the power tubes may conduct so heavily when they get gassy that they will cause a hum before total failure. The tubes will first get red, then orange plates and that drives metal ions out of the plates, then they get a purple glow and eventually blow the fuse or something in the power supply.
May 07, 2011 | Randall RT Series RT100H 100W Tube Guitar...
Dryer does not get hot under a load
disconect the vent hose if problem persist change the coils
Mar 03, 2010 | Dryers
My black and decker water cooler makes noise like its boiling water which I know it does but it's much more pronouced and more frequent than before.
Slight boiling noise aside, a loud and unbearable rattling noise plagued my B&D Hot and Cold Water Cooler (top load). DIY Solution: The issue was some sort of copper coil vibrating against the front panel cover (just behind where you would place a glass. This copper colored coil is attached a canister looking thingy ma-bob, with a long black arm that is runs to the bottom right of the back cover. By removing all four screws on the back cover, you may angle (bottom out) the cover enough to gain access to this arm. GENTLY... lift the arm/rod so that the copper coil is no longer touching the front panel (and thus it is free to vibrate without that annoying noise). CAUTION: unplug the unit and ground yourself to avoid shock. Once you can see the coil is no longer touching, plug-er back in and see if the noise has stopped. Perform above at own risk.!!!!!
Aug 01, 2009 | Whynter FX-6SW Free Standing Hot & Cold...
It runs but no there is no hot air
the first thing you want to make sure is that the igniter is working, remove the orfice on the front of the dryer, an start the dryer cycle, it should glow if it doesn't then you have a bad igniter, if the igniter glows an you have no heat (at all) you want to check the thermalfuse onthe dryer, check for continuity with a voltage tester it it beeps means is ok , if it doesn't pass current replace it,
if you get partial heat only then it would look into the coils, the 2 coils are inside on the front of the unit. coils are replace for the most when your dryer takes a longer cycle meaning it takes longer to dry or finishes an clothing still damp.
good luck.
May 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Reebok 8500 ES treadmill - noises
You should check the motor and the rollers. There are oil joints that can possibly use some oil or the motor is going bad. The way to check the motor is with a volt meter or to check it with your hand after running it for 5 minutes without a load on it. If it is very hot then replace the motor. Most noise problems come from the rollers bearing which usually just need to be oiled and not replace. There is a cover behind the big roller that can be removed to look at the problem
Feb 11, 2009 | Reebok 8050 ES Treadmill
Exercise & Fitness Logo
37 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
