Question about Candy Ovens
Candy FPP6071X led clock is on but oven will not work
My Candy oven LED display showed Auto and I have managed to turn that off but the oven still won't work any ideas?
docjohn174
  • 943 Answers
SOURCE: kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Posted on Oct 05, 2008
barkencoa
  • 3463 Answers
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Posted on Feb 22, 2010
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
  • 25 Answers
SOURCE: Candy Electric Oven no power in oven/grill at all, only clock
is the timer set, most ovens wont work if the timer is not set
Posted on Apr 07, 2010
blackmar
  • 235 Answers
SOURCE: Recently bought this oven (without
I come across this problem often, particularly with no manual. I turn the oven to ON. I then just muck around with the buttons until I find the manual setting. As soon as you find the manual setting the oven indicator will light. You can normally work it out quickly. But make sure the oven is turned to on whilst you are doing this.
Posted on Feb 05, 2011
blackmar
  • 235 Answers
SOURCE: Since a power cut yesterday,
If you cannot change it from auto. to manual it doesn't mean you need a new oven. The electronic timer can be by-passed fairly easily by joining the active and oven load wire together..
Posted on Feb 11, 2011
Testimonial: "Fab... just done the necessary changes - connected blue & red wires on LHS (as you view from the front) and hey presto all is working :-) thanks"
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
My Candy FPP6071X oven won't heat up. The grill and everything else is working fine. Any suggestions?
As you can see on the electrical diagram grill heating element (RG) work alone or in seria with inner lower heating element (RI) and based on the your statement, I conclude that does not work lower heater (RD). So, you should check resistance of lower heater (RD), contacts of change over switch (P7-7 and P6-6) and wiring. By the way, both heater (RI + RD) is integrated into a single heating element.
Dado
Feb 22, 2015 | Candy Ovens
I have a Fisher & Paykel OS302. The temperature and oven mode selects are dead, no LED display, no operation. The clock module is working. This happened all at once, I tried to turn it on and both...
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
Feb 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
Recently bought this oven (without instruction manual) I cannot get it to start working! When turned on digital display flashes and oven is on auto. How do I set the clock and oven to manual. the oven...
Feb 05, 2011 | Ovens
The LED display is barely visible. Both for Timer and Oven Temp.
Problem with Frigidaire CFEB27S2AB2 Electric Wall Oven.
My LED display on my clock has the 3rd number not showing up all the
light. Sample 10:30 the 3 on the top is not light. What is the problem
Jan 07, 2011 | Frigidaire FEB27S5A Electric Single Oven
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
LED display stopped working
Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
Jan 04, 2009 | Belling XOU252 Electric Single Oven
Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Nov 22, 2008 | Neff U1721 Double circotherm Electric Oven
Kenmore model c970-655632 LED Display is very dim
Oct 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Candy Ovens Experts
ashburton
ray gallant
Gaark
Are you a Candy Oven Expert? Answer questions, earn points and help others
