Usb port 2.0
Since my iphone does not appear in iTunes when connecting it, I need to find out which one of the three USB ports in my computer is a USB 2.0 output. Please help?
  • 34 Answers
On your desktop, search for an icon Computer.
1) Right Click Computer & select manage
2) Select device manager
3) On right side, you will see an Option -- Universal Serial Bus Controller
4) now connect you iphone to different USB ports & you will be able to see the one in the device manager also
5) Right click on that USB which gets selected & select Properties.
You will be able to detect it
Posted on Feb 08, 2012
sandrew
  • 2961 Answers
SOURCE: USB ports not working Acer Aspire laptop
Two solutions would be to either restore your pc to before the problem started,using system restore on accesories menu, or use the recovery cd or the recovery folder Acer laptops usually have on the 'D' drive and re-install usb controllers and drivers.
Posted on Nov 24, 2006
StuartB
  • 807 Answers
SOURCE: usb port on Acer aspire 5050
Be safe rather than sorry, get yourself a Powered USB Hub.
One of the problems with USB is that a device is only allowed to draw up to 500mA of power (100mA on first connection). So, if you buy a non-powered hub, it will only support one high-power (500mA) peripheral, and the other ports on that hub may be useless. Plug a mixture of devices into a non-powered hub and some might work while others might not. Since people expect to be able to plug any USB device into any USB port, I think this is really bad. Using a powered USB hub generally eliminates the problem.
Posted on Mar 25, 2008
Pyrhyc
  • 2028 Answers
SOURCE: replace broken usb port on dell latitude laptop
You will have to take the machine apart somewhat, or at least to the point of being able to disconnect and remove the usb port. Here's a link to the D600 service manual download. It will guide you through the breakdown process.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
Posted on Jul 27, 2008
mediarich
  • 188 Answers
SOURCE: t40p usb 2.0 ports acting like usb 1.0
There is no hardware or software fix for this. Here is a thread on what might be your problem. http://forum.thinkpads.com/viewtopic.php?t=67571
Posted on Sep 25, 2008
9339009664
  • 70 Answers
SOURCE: 2 of 4 USB Ports Not Functioning
i think u r using pirated windows. nad ur autoupdate is on. i think if u reinstall windows it may work fine. i suggest to format c: and reinstall window to be sure
Posted on Aug 23, 2009
ITunes could not connect to the iPod touch because an invalid response was received from the device.
"iTunes could not connect to the iPod because an invalid response was received from your device" troubles a lot of users.
iTunes Could Not Connect to the iPhone iOS 10 iTunes Invalid Response...
Here are the best four methods for you to refer to fixing this iTunes could not connect to the iPhone invalid response problem, via updating iTunes and iPhone, uninstalling and reinstalling iTunes, and using iTunes alternative.
May 14, 2017 | The Audio Players & Recorders
My apple ihone is disabled connectto itunes
There are many reasons why iTunes will not recognize your iPhone, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
1. Generally speaking, when iTunes does not recognize iPhone, it may have something to do with the version of iTunes. If you are using an old version of iTunes on your computer, it may not be capable of recognizing your iOS devices. So updating iTunes to the latest version is a fastest way to get the problem solved.
2. If you are running iTunes in the latest version, but still can't get your iPhone recognized, you may want to take a look at your computer, sometimes if your computer lacks necessary software, it might lead to the malfunction of iTunes.
3. USB port on your computer can be another reason why iPhone not recognized by iTunes. So you can try more than one USB port to see whether the USB port works well.
4. Of course, your iPhone may also be the cause of iTunes not recognizing iPhone. At this moment, you can restart your iPhone by holding the Sleep/Wake button and Home button at the same time until you see the Apple logo, then connect iPhone to computer with USB cable again.
5. You should also make sure your iPhone trusts your computer, because after changing a new system on computer, your iPhone will regard it as a new computer. What's more, you should check out whether Apple Mobile Device Support is installed on computer.
6. After checking out all the aspects mentioned above, you can try to connect iPhone to computer with the USB cable again.
If none of these methods work out, you may want to try set your iPhone up as new after iTunes not recognizing iPhone. You only need to tap General > Settings > Reset > Erase All Content and Settings, and then choose Set Up as New. When you have set iPhone up as a new device, you are able to connect iPhone to computer with USB cable. But before erasing all contents on your iPhone, you may want to back up iPhone files to computer to keep them safe.
http://www.leawo.org/tutorial/what-to-do-when-itunes-not-recognizing-iphone.html
Feb 07, 2017 | Apple iPhone Cell Phones
USB port for iphone sync
The iPhone will sync to iTunes on a computer. If the display has a USB port, there must be another USB cord to the computer. The iPhone will go through it to get to the computer.
Apr 15, 2014 | Atlona ATNO-AT13033-2 - AT13033-2 6FT Mini...
My iphone says disabled connect to itunes but itunes doesnt read.
Have you tried using a different USB port? Sometimes certain USB ports on a computer stop reading the device. Try using a different computer. See if that one reads it.
If all else fails, you may need to DFU-Restore the iPhone.
In order to do that:
1. Turn off the phone. 2. Hold down the power (the top right) and the home buttons. 4. Once the apple logo comes on, stop holding the power, but keep holding the home button. 5. Open up iTunes. It should say the phone is in restore mode. 6. Do your restore.
Cheers.
Mar 16, 2011 | Apple iPhone Smartphone
How to set up my iphone
here are useful tips for your iphone set up.
Please read the Activating and Setting Up Manual Instructions below -
What You Need - To use iPhone, you need:
• A new wireless service plan with the carrier that provides iPhone service in your area
• A Mac or a PC with a USB 2.0 port and one of the following operating systems:
• Mac OS X version10.4.10 or later
• Windows XP Home or Professional with Service Pack 2 or later
• Windows Vista Home Premium, Business, Enterprise, or Ultimate edition
• Display resolution on your computer set to 1024 x 768 or higher
• iTunes 7.5 or later, available at www.apple.com/itunes
• An iTunes Store account (a major credit card is required to open a new account) â An Internet connection
Activating iPhone
Before you can use any of iPhone's features, you must activate iPhone by signing up for a service plan with the iPhone service carrier in your area and registering iPhone with the network. If you already have a wireless account with the carrier, you may be able to upgrade your account to work with iPhone, or keep using your old phone and add a new line for iPhone. (Some accounts may not be upgradeable.) You may also be able to transfer your current phone number to iPhone, or get a new one.
For more information about iPhone, including videos about how to activate and use it, go to:www.apple.com/iphone
Inserting the iPhone SIM Card
In some regions, you may need to purchase the SIM card separately and insert it into iPhone before activation. Read the documentation that comes with the SIM card for instructions.
If your carrier gave you a PIN number to use with your SIM, you may need to enter the PIN before activating iPhone.
Activate iPhone
1 Download and install the latest version of iTunes from www.apple.com/itunes.
2 Connect iPhone to a USB 2.0 port on your Mac or PC using the dock and cable that
came with iPhone. Unless your keyboard has a high-powered USB 2.0 port, you must connect iPhone to a USB 2.0 port on your computer.
3 Follow the onscreen instructions in iTunes to activate iPhone and sync iPhone with
your contacts, calendars, email accounts, and bookmarks on your computer. A single checkmark in "Set Up Your iPhone" syncs all these items automatically. Or you can use iTunes to customize the information you sync, and to sync your ringtones, music, photos, podcasts, and videos to iPhone. See the following section.
You can disconnect iPhone from your computer after "Waiting for activation" appears on the iPhone screen. When activation is complete, "iPhone is activated" appears on the iPhone screen. This means that iPhone is fully functional and you can use all of its features.
Important: If you are migrating your current phone number to iPhone, activation may take from several hours to a day and migration of your number may take several days, depending on your location and previous carrier.
Syncing iPhone with Your Computer
When you connect iPhone to your computer, iTunes syncs iPhone with the information and media on your computer, according to how you've configured the iPhone sync settings in iTunes.
You can set iTunes to sync any or all of the following:
• Contacts - names, phone numbers, addresses, email addresses, and so on
• Calendars - appointments and events
• Email account settings
• Webpage bookmarks
• Ringtones
• Music and audiobooks
• Photos
• Podcasts
• Videos
Ringtones, music, audiobooks, podcasts, and video content are synced from your iTunes library. If you don't already have content in iTunes, the iTunes Store (available in some countries) makes it easy to purchase or subscribe to content and download it to iTunes. You can also add music to your iTunes library from your CDs. To learn about iTunes and the iTunes Store, open iTunes and choose Help > iTunes Help.
Contacts, calendars, webpage bookmarks, and photos are synced from applications on your computer, as described below. Contacts and calendars are synced both ways between your computer and iPhone. New entries or changes you make on iPhone are synced to your computer, and vice versa. Webpage bookmarks are also synced both ways.
Email account settings are only synced from your computer's email application to iPhone. This allows you to customize your email accounts on iPhone without affecting email account settings on your computer.
Feb 01, 2011 | Skque SKIN Case COVER Earphone Set FOR...
How to fix my iphone 3gs having icons of usb pointing up to the icon of itunes then slide emergency call?
your iphone needs to be synced with itunes or activated with your service provider.
1. open itunes on your computer
2. plug your iphone in to a usb port on your computer
3. follow the instructions on the screen
Nov 09, 2010 | Apple iPhone 3G
Iphone screen frozen, also phone not showing up in itunes...
iPhone may exhibit a problem where it does not respond to any button, switch, or touchscreen input.
To turn it off, press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPhone.
To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
If the iPhone remains unresponsive after trying the above steps or if it is in a different state, such as showing a persistent Apple logo on the display, try resetting the device:
Before following the steps you need to take a backup of your iphone
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
When you connect your iPhone to your computer, an iPhone icon should appear in iTunes in the left column under Devices. But if it doesn't, this troubleshooting assistant can help.
1. Make sure your computer has the following:
  • Mac OS X version 10.4.11 or later
  • Windows Vista Home Premium, Business, Enterprise, or Ultimate Edition
If your computer does not meet these requirements, you will need to upgrade your computer before using iPhone.
2. If iPhone is very low on power or if the battery is fully depleted, it can take up to 10 minutes to appear in iTunes.
3. Connect iPhone to a USB port that is built into the computer instead of the keyboard or an external USB hub.
If iPhone still doesn't appear in iTunes, try a different USB port.
4. Restart the iphone:
To restart iPhone, first turn iPhone off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPhone will turn off after a few moments.
Next, turn iPhone on by pressing and holding the Sleep/Wake button until the Apple logo appears.
If iPhone not responding? To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
5. If you face the same issue reinstall the latest version of itunes
If this does not resolve the issue, try completely uninstalling iTunes and then reinstalling the latest version of iTunes.
Even after following the steps if you face the same issue, then it must be some third-party software (such as security software, anti-virus software, and webcam drivers) may prevent iTunes from recognizing your iPhone. You may have to update your software, adjust software settings, or temporarily disable the software.
In Windows, MSCONFIG is used to troubleshoot conflicting software. For assistance using MSCONFIG, select from the following:
XP | Vista
Jan 13, 2010 | Apple iPhone Smartphone
Iphone will not restore error 13
You can resolve the restore issues using the troubleshooting steps found in this document:
1. Update to the latest version of iTunes
To see if you have the latest version of iTunes, open iTunes and check for updates.
  • Windows: Choose Help > Check for Updates
  • Mac: Choose iTunes > Check for Updates
If there is an update to iTunes available, install the update and try to restore again. If you do not have an active connection to the Internet, or your Internet security settings are configured to prevent iTunes from communicating with Apple, iTunes will alert you that the iTunes update server could not be contacted. Resolve your Internet issues and attempt to update again.
2. Restart your computer
Simply restarting the computer can clear up certain issues that could prevent you from restoring iPhone or iPod touch. After you restart, try restoring the device again in iTunes.
3. Open the proper ports and allow access to Apple servers
During the update and restore process, iTunes needs to contact Apple. Ensure that your computer has the following ports open and can access these servers:
Port 80
Port 443
phobos.apple.com, albert.apple.com, gs.apple.com
If you see "Error 9807", you must open access to the following VeriSign servers:
evintl-ocsp.verisign.com
evsecure-ocsp.verisign.com
If you are using a Windows operating system, you can follow this article to help resolve issues caused by third-party security software.
You may need to update, properly configure, disable, or uninstall built-in firewalls and other security software to prevent interference with iTunes. For assistance with this, contact the company that supports the firewall or security software you use. If you are using proxy settings, try to restore or update without using a proxy.
4. USB Troubleshooting
Connect iPhone or iPod touch to a different USB port on your Mac or Windows PC. USB 2.0 ports that are built in to the computer are preferred over a hub. If you tried connecting iPhone or iPod touch to USB ports on the front of the computer, try connecting them to rear USB ports. After doing this, try to restore the device in iTunes.
If the issue continues:
Remove all USB devices except the keyboard, mouse, and iPhone or iPod touch. Remove all USB hubs and connect directly to the computer.
Connect iPhone or iPod touch directly to the included USB cable, bypassing the dock.
Restart the computer.
Try to restore the device again in iTunes.
If available, test with alternative, known-good USB cables.
5. Restore on a different computer
If the issue is not resolved with the above steps, try to restore using a different computer. Ensure that the computer you use has USB 2.0 ports, the latest version of iTunes, and that you connect directly to the computer.
If another computer is not available, proceed to the Advanced Steps below.
Oct 17, 2009 | Apple iPhone 3G
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Acer Ferrari 5000 with Ituner8 and Iphone
sounds like a problem with the iphone , did you try a different usb port?
Oct 08, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
