Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
John Deere 6400 will not stay in gear
Jumps out of gear when cluch is released
wireguy212
  • 1627 Answers
SOURCE: where is the hood release for the 3320
Below the bottom of the hood you will find two metal tabs,push down on either one to release the hood.You will have to release the grill guard pin and roll it forward before the hood will open all the way[if it has a loader on the tractor].Under the hood and to the left of the battery is the prop rod to hold it up.Hope this is helpful.
Posted on Jan 02, 2010
wireguy212
  • 1627 Answers
SOURCE: how do I change the temp gauge on a john deere
The temperature gauge is built into the instrument cluster and it needs to be changed as a unit.Try removing the wire from the temperature sensor and ground it to the frame of the tractor to verify that you do need the instrument cluster replaced,ground that wire will drive the gauge to hot if the gauge is good and nothing will change if it is defective.If grounding the wire made it work then you need a temperature sensor.Good luck and let me know how you make out!
SOURCE: Need Sevice and repair manual for a 6400 john deer
Please email dcooper5126@yahoo.com. I would like to copy your technical and operators manuals, mine i think my x swiped, i really need them,,,,,,thx
miss delynda
Posted on Apr 03, 2010
  • 5 Answers
SOURCE: john deere 6400 4 wheel drive rock arm calibration
should be able to calibrate with a screw driver on top of the cap of the senser on the back of the tractor
Posted on Jul 09, 2010
SOURCE: hydraulic reverser problem with John Deere 1010
ineed to find a hydraulic reverser for a 300D john deere backhoe
Posted on Nov 23, 2010
John Deere 8330 PTP 524271.05
Try adjusting the linkage on the shifter the shifter may not be adjusted properly so the gears are not being fully engaged ,extend the linkage at least an inch or two (lengthen it)
Jun 23, 2015 | John Deere 2006 8330 69141
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Jugn deere 6400 manuel
You can download the appropriate manual from the manufacturer's web site at
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&tM=FR&searchCriteria=6400&language=english&submit=Search
Aug 01, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
miss delynda
Sep 18, 2009 | John Deere Tractor Side Screen...
John Deere LT 133. Will not move with mower in gear and clutch/brake released. A smell like hot rubber prior. Mower will engage. Thanks.
It could be that the belt jumped off the pulleys and got caught between a pulley and a belt guide,or the trans-axel seized up ,or brake was stuck while in a high gear,and burned up the belt. most likely the first reason. if it wasn't for the burning rubber smell,I would also look for a broken clutch/brake return spring .The pedal would stay down with a broken spring
May 24, 2009 | Garden
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
