Question about RCA P46924 46" Rear Projection Television
RCA P46924 64" Rear Projection TV
My television does not show any video from any output sources, from Cab/Sat (connected to Digital Cable Tuner), Input 1 (Connected to DVR), or Input 2 (Wii Console) all connected through standard RCA/Video-Audio Cables. Sound between the inputs works. The TV's OSD (On-Screen Display) shows for Picture Settings, Setup, etc. Does anyone have any idea where I should begin to troubleshoot this problem? Any help is much appreciated.
  • choicey1 Oct 23, 2008
    Thank you, Schwangod!!!!! :o)
    I unplugged the power cable, took the back off, blew out the boards with canned air, plugged it back into the power strip and Waaa Laaa! Upon powering it back up, the TV forced me into Setup Mode as it detected a total loss of power so I had to re-setup each device. The result was White Noise on cable channel (I disconnected the cable) and only connected the DVD Player on Video 1. I took your advice and did not reconnect the Wii ( Uuugh....No more beating up my boss in Boxing.....). I suspect the complete power off forced reinitialization of the video ports on the main board to clear the interference the Wii caused? Thanks again!
    Problem Solver:
  • 10 Answers
Disconnect the wii it will eventually ruin your tv game systems can't be used on rear projection because of problems caused you may need to hook everything up at the bottom of the panel and switch back and forth using your remote we had to do that on ours
Posted on Oct 23, 2008
  • schwangod Oct 23, 2008
    ur welcome
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
How should I hook up a dvd player? Which one of the input jacks. I am using rca connectors
mikehomco,
On the rear of the DVD locate the composite video output and audio outputs. The connectors will be RCA females. Video is yellow, right audio is red and left audio is right. Connect one end of your patch cable to the appropriate output color. On the TV find the video input one. Connect the yellow, red and white ends of the cord to the same colors on the TV, video input 1. If your TV has a source selection button use it to locate video input one. If not use the menu. Go to input select and choose video input one. Enjoy the movie.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 24, 2011 | JVC HD-52G886 52" Rear Projection HDTV
We have a RCA D52w19 rear projection tv. It appears that the HD feature is not working. My Wii does not recognize it as HD and the picture for Wii, satellite and DVD is noticeably grainy. Is there an easy...
The Wii is not a HD output source. It only displays 480p. If you wish to connect an HD source, you must connect through an HDMI cable or a component Cable. HDMI is better.
Feb 28, 2011 | RCA D52W19 52" Rear Projection Television
Our RCA D52W19 TV is playing in standard 480dpi (Satellite, DVD, and Wii). How can we get it to play at 1080dpi, like it used to?
2004 jvc 56in projection tv, has sound but no picture
Hello
Change the channel to ensure the problem isn't with the current station broadcast. Check the channel at a later time to see if the broadcast problem is resolved.
The type of programming you are trying to watch determines the proper input source. Press the "Input" button on the remote control to change to the proper input source. For example, if the source is a cable or satellite service, press the "Input" button until "TV" mode is selected. A component device, such as a DVD player, will operate on a different input source, such as "Video-1."
Check the coaxial cable, which connects your television broadcast service provider to your television. You need to securely connect the coaxial cable to the "ATSC/Digital Cable In" jack on the back of the television, and the other end to the wall jack. If the cable appears damaged, replace it with a new cable.
If you are using a component device as the source of your programming, ensure the component cables are plugged into the "Video Input" and "Audio Input" jacks on the back of the television or that the S-Video cable is plugged into the "S-Video Input" jack on the back of the television. Connect the other end of the cables to the "Video Output" and "Audio Output" jacks or "S-Video Output" jack on the component device.
Oct 02, 2010 | JVC AV-56WP84 56" Rear Projection...
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
Having trouble connecting Protron Model PD-007 to cable tv
are all your connections correct, (is tv on ch 3) dvd output to tv (coaxial or digital in) using tv remote make sure the source is air (or cable/sat ).. put dvd into player press play let load a picture should show (unless you are connecting with RCA wires then the tv would be on ch "video" this would be below ch 2
Jan 26, 2009 | Protron PD-DVR100 DVD Recorder
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
Sep 27, 2008 | Televison & Video
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
RCA P46924 46" Rear Projection Television Logo
270 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
