Question about GE ZET2SMSS Double Oven
Both door will not lock when i start the self cleaning
I have a double oven and both doors won't lock. aren't they supposed to?
    Problem Solver:
  • 18 Answers
U have to push the grey round butten that said start by the clock
Posted on Nov 09, 2011
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
What is the f7 fault code
I have the double wall ovens. The lower oven read door lock & flashed F7. Check to make sure the lock is not sticking out a bit, it is on the left side of the oven. I'm not sure if this is what the f7 fault code is, but it worked for me :)
Nov 24, 2010 | Fisher and Paykel AeroTech Double OD302...
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
"Door Locked" keeps flashing
Was able to get the lock to go in on the door and then turned off the power which reset the system.
Mar 31, 2008 | GE Profile JTP56 Electric Double Oven
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
GE ZET2SMSS Double Oven Logo
43 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
