Question about Frigidaire Dishwashers
Frigidaire dishwasher FDB4050LHS1 won't start. Does the control panel need to be replaced?
All the control panel buttons and lights work except the "Start/Cancel" button and the "Delay Start" button. When those buttons are pressed, nothing happens.
  • 76 Answers
SOURCE: dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Posted on Jun 29, 2007
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
SOURCE: Touchpad--No Response
See the notes about cycles taking forever. The relay that controls the heating element commonly gets warm enough to melt the solder around the connection, and the internal water heater stops heating. The "2H" indicates how much time the onboard computer thinks it will take to wash the load, based on previous loads, but if the last cycle was longer than 99 minutes, it shows 2 Hours. Repairing the controller board (or replacing it) should solve the problem. This is such a common problem, Bosch should have had a recall, but didn't.
Posted on Aug 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Posted on Jul 17, 2010
We have a Frigidaire dishwasher there is a p/n: 154881401. Its only about 1 year old but all the light will light up when.pushed except the start and cancel button. Already tried cutting power.
Good Afternoon Denise, thanks for your post!
Based off what you have described your Frigidaire dishwasher will light up and will not start or cancel. This could be a possible problem with your keypad or control panel. In order to access which electrical component that could be causing the issue you would need to disassemble your dishwasher. This is not a simple DIY job and I would recommend having a professional technician for proper diagnosis and repair. This will help you avoid unnecessary part purchases. -Matt
Apr 10, 2015 | Frigidaire Dishwashers
Green normal light is on but none of the buttons including start button work
Hello friend, thank you for your post!
I understand that the light on your Frigidaire dishwasher is lit as it normally is, except it will not operate. It is possible that your dishwasher may have an issue within the keypad or control panel. You can perform a reset, in the case that it is a miscommunication error within the dishwasher. You can reset the dishwasher by flipping the household circuit breaker off for at least ten minutes. If this does not help correct your issue I would recommend seeking assistance from a professional technician for a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Nov 22, 2013 | Frigidaire FFBD2406NS Built In Dishwashers
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Washing light is flashing and dishwasher won't start
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 19, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
104 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
