Question about Lexmark Office Equipment & Supplies
Lexmark X83 Changed black cartridge print warns Black ink low Prints so faintly can't be read
  • 903 Answers
The printer heads probably need cleaning. If you go to control panel>printers and scanners> right click the printer you are using> click in properties, there should be an option there for maintenance. Choose clean print heads. When the heads have been cleaned print out the result. If this has improved but is still a bit faint repeat the steps until the page is clearly readable.
Posted on Oct 23, 2008
    Genius:
  • 1,913 Answers
Pull the artridge again and refix again.
also if u get same eror change your cartridge.
Changed black ink caertridge but still getting the low ink warning
If you are using a remanufactured cartridge, the low ink warning is actually normal. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridges are remanufactured, the chip is unable to be reset. Here is a link to a site that sells remanufactured cartridges on how to bypass the low ink warning on Lexmark printers:
http://swapink.com/Merchant5/merchant.mvc?Screen=lexinst
Nov 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Some time it prints in pink
Do you see the color cartridge icon in the progress window being low ?. Or do you get an low ink warning dialog when you print a job. First try cleaning the cartridges if that doesnt help, you may need to replace your color cartridge.
See the below link for cleaning your cartridges, the procedure is near the end of the page:
http://support.lexmark.com:80/perl/support/support.cgi?relevance=0&ccs=229:1:0:537:0:0&mode=DOCS&doctype=KB&term=clean&docid=ENUS30978
Jun 01, 2009 | Lexmark X1270 All-In-One InkJet Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Jan 24, 2009 | Dell 922 All-In-One InkJet Printer
Lexmark X83 prints streakily or not at all
Have you used a new cartridge.
Do the test for running and cleaning new cartridge heads and the alignment procedure..
(Go to Start, settings, printers, right click on printer then click properties, cartridge maintenance.)
Other thing that might cause problem is build up of ink in right side of machine below printer cartridges.
You will have to strip down machine to get at this area.
Make a note of exactly what action you take when doing this so that you can bits back together.
I use cotton buds to get at the build up of ink or tissue wound round end of pointed object.
Go gently. When you have cleared what you can care reassemble bits and go through above procedure again. Check for any unusual noises that may denote part of mechanism has worn.
Alleluia
PTL
Nov 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 - Changed the black cartridge according to the instructions. Message says Warning low on black ink. Page prints so faintly can't be read.
refix again cartridge also check there is not any paper jam or lekage in cartridge.
clean on bottom surface of cartridge on which u put it.
Oct 22, 2008 | Lexmark Office Equipment & Supplies
Black cartridge not activating properly
There's a blue protective strip on the bottom of the cartridge when you buy it, and it needs to be removed before you put the cartridge in the printer.
May 16, 2008 | Lexmark X83 All-In-One InkJet Printer
Printer won't recognize new ink cartidge
Most common problems like this come from non-genuine cartridges, or refilled ones.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
211 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
