Question about Kenmore Dishwashers
Mi lavadora kenmore he3 no enciende ninguna liz
Mod. 110 45872 402 kenmore elite he3 quiet pack
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
  • 163 Answers
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Posted on Mar 06, 2009
SOURCE: lavadora kenmore HE3 parpadea la luz de delay cuando faltaba 15 minutos para terminar el ciclo.
necesito instrucciones de uso de mi lavadora kenmore Elite pero en español
Posted on Jul 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
SOURCE: I have a Kenmore Elite
i just had this problem... i did the following (should only take 30 minutes) take the panel off, that is located below the front door,, there are 3 small srews located at the bottom that hold this... then you will see the water pump, the water pump has a access srew plug, when you unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean it, then put everything back... this should fix the issue.
Posted on Oct 23, 2010
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Mi lavadora crosley no funciona solo dos luces enciende
Mi lavadora prenden las 2 luces primera y ?ltima lava un minuto se para y centrifuga
Jan 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
Dec 05, 2012 | Dryers
Lavadora kenmore osasis he, pierde agua por abajo
tengo un problema con mi lavadora kenmore elite oasis he q cuando la prendo me aparese un 60 y ah se queda ????
Feb 29, 2012 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore Elite Quiet Pack 2, HE3, model number 110.45872 400 front loading washing machine. When I start a cycle it stops and letters H and F alternately show on the screen. What does this mean?
Oct 11, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tengo un Kenwood KMR-330 y me dice en la pantalla PROTEC y no enciende y no hace ninguna funcion.
tiralo a la basura yo tampoco pudo hacerlo funcionar te vendo el mi maybe de los dos salga uno
Apr 28, 2010 | Kenwood KDC-MP442U
My washing machine is knocking during the spin cycle.
mi lavadora se detiene y marca el codigo 11 f es una kenmore elitte HE3 GRAICAS
Jan 18, 2010 | Whirlpool Washing Machines
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
DRYER WILL NOT HEAT!!! HELP!!!/Kenmore HE3 Dryer-Mod.# 82822102
first its always important that you give make and model as different makes have different repair proceders for repair the easyiest thing to do first trust me is to turn the breaker off then on then try drier and let me know what you found now dont rate me till we are done ok
Jan 02, 2008 | Dryers
Dishwashers Logo
173 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
