Question about Freezers
Not sure what colour buttons should be illuminated when working
Undercounter integrated white westinghouse
  • 21 Answers
Hiya Mary, i have an undercounter freezer but not your make but my buttons light up green, orange for fast freeze. hope i was some help to you.
Posted on Feb 08, 2012
Testimonial: "Hi Pauline, thanks for your help."
Freezer temp set at -4 but temp stays around 26
freezer section not working
get a fridge technician in to check / repair.
May 21, 2015 | Everest Refrigeration ETRF2 - Undercounter...
My freezer was running a lot I guess the over load tripand stop working.replaced overload and relay and my gauges indicate high back pressure any ideas how to fix it
High back pressure is generally a sign that the evaporator coil is clogged with debries or the fan isn't working I suggest checking this first.
Oct 11, 2013 | Silver King 1242.90 Front Breathing...
My kenmore elite undercounted ice maker keeps blowing the reset button the outlet located on the wall nearby. We hadnt had an issue with the reset button prior to a recent repair made to motor and...
Maybe there was something bumped or overlooked during the cleaning/repair process like a cooling fan?
Did you add any other appliances to that circuit before/after/during the repair to increase amperage draw on the breaker?
Try replacing the overload protection outlet with a new one as it may be faulty/worn out. Good luck
Jul 20, 2011 | Kenmore Freezers
There is a leak in the evaporator. Where can I buy spare parts in the UK
Here is my video how I replaced evaporator on undercounter refrigerator.
Sep 29, 2010 | Freezers
I have a undercounter front opening doorDelfield freeze
Hi debbie. Before you hire any repair man please price a new one. The new ones run on 1/6th the electric as the old and they are often under $200. Check them at Home Depot or lowes, even KMart which now handles the Kenmore/searss line. I believe you will end up replacing as opposed to repairing.
Aug 04, 2009 | Freezers
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
How do you adjust a Westinghouse 2 dooe refrigerator door
Loosen the top hinge screws.
Pull up on the door to where you want it.
While holding the door in place, re-tighten the screws.
Mar 11, 2009 | Frigidaire Freezer Refrigeration White...
White Westinghouse upright freezer not cold enough.
Coils are probably underneath. remove the grille at the front (usually you just rotate it down to pull off) and then vaccum inside with a wand. If there aren't any coils there either, pull the machine out from the wall, and remove the lower panel from the back side. Inside you should find a fan next to a coil. Make sure that fan is working, and if it isn't make sure it is getting power.
Vacuum out as good as you can, and if you can use compressed air to blow it clean, even better (vacuum first because it will kick out a lot of dust).
If vacuuming the coils doesn't work, then you probably have a freon leakage problem, in which case it is probably not worth the cost of repair.
Mar 06, 2009 | Freezers
Freezers Logo
304 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
