Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire electric dryer front loading wont start
The dryer was working fine, i just finished drying a load and when I went to start the next load the dryer sounds like its running, but wont tumble
  • 4 Answers
My motor locked up and made a humming sound. I took the back panel off and turned the drum while my wife hit the start button. It started up so I sprayed it with WD-40 on the bearing and motor shaft, it works every time now
Posted on Jan 11, 2012
    President:
  • Frigidaire Master
  • 2,651 Answers
Sounds like you have a broken belt
Posted on Oct 25, 2008
Kitchenaid dryer drys fine the first load then it gets louder the next load then stops working
Sounds suspiciously like worn support roller shaft bearings. When they get bad sometimes the rollers just wobble on the shaft and eventually, if the dryer isn't shut down and repair quickly, the shafts will become severely worn and will need to be replaced as well as the rollers. It will most likely have to be disassembled before a good estimate can be made.
Dec 24, 2011 | KitchenAid KEYS750LQ Electric Dryer
We have a Frigidaire gas dryer about 2 yrs old. I placed a load of towels to dry (at "Towel" setting) everything went fine. I placed the next load and chose "Normal" setting. The...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 25, 2011 | Frigidaire Dryers
I was drying, a load finished fine. Put the next load in, turned the knob for setting and I got the error code of "PR" and it wont turn on. The display is not working. So I unplugged it, then reset the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 30, 2010 | Electrolux Frigidaire Affinity AGQ8700FE...
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
My dryer doesnt work
check the door swich to be sure made up properly
Dec 29, 2008 | Kenmore 659 Electric Dryer
I have a kenmore electric dryer it worked fine i dryed a load of clothes in it and went to dry another load and it wont turn on i set the knob to tempature to dry my next load and push the start button and...
This may be a thermal overload switch which is probably located underneath the top of the dryer. When you find it, bypass it to see if that is the problem. If so, replace it for about 10-12 dollars. Check the breakers first, then the connections in the back to see if they are secure.
Frigidaire GLEQ2152ES just hums when you start it... doesn't turn
Unfortunately, this is probably a bad motor, part # 131560100. It retails for $129 but can be found for around $100 shipped online. You can inspect for a clogged blower first by removing the front panel.
Dec 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Affinity ATF7000E Front Load Washer Logo
291 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
