Question about Garden
MAKITA DPC6430 RUNNING LUMPY
WORKING FINE THEN RAN LOW ON FUEL. THEN STARTED TO RUN ROUGH
keemo68
  • 1263 Answers
SOURCE: Ran out of gas and now she won't run!
i would say that you have a bad fuel pump or if you have a carb on it the float inside the carb is stuck check these and i'm sure you will find it's one of these.
Posted on Sep 06, 2008
  • 16 Answers
SOURCE: 1998 Plymouth Breeze
change your sparkplug wires that will salve yor problem
Posted on Dec 11, 2008
  • 1118 Answers
SOURCE: engine turns over fine , car will not start.
well the first part of your question i was all ready to tell you to put a new fuel pump in, now not so sure, there is a relay for fuel pump, can you hear pump cycle and relay click? relay under hood you will have to listen close they don't run long maybe a couple secounds, if you don't relay bad. if you do pump could be bad, do fuel pressure test pump could be weak. don't think sunroof and turn signals are related, but stranger things have happend.
Posted on Jan 25, 2009
SOURCE: Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Posted on Mar 19, 2009
beduncan
  • 73 Answers
SOURCE: running rough
If your car is running rough and it's fuel injected (which yours is). Follow the air intake (black plastic box - housing the air filter that has tubing that goes to the motor) until it reaches the Throttle body (rounded metal air intake at the end of the plastic tube - has one large flap inside). You will want to remove the hose clamp and thoroughly clean the throttle body and the AIC (air idle control valve - small canister attached to the throttle body). Use off-the-shelf cleaner from any automotive store. This takes about 30mins to 1hr depending on your skill level. This will result in a cleaner smother idle and smoother performance. This is a common issue in today's cars. I have to do this once a yr to keep my modified car running happy.
Take a look at the later parts of this article for pictures to give you an idea:
http://forums.nicoclub.com/zerothread/319146
Good Luck
Posted on Aug 07, 2009
Engine running very rough
could be bad fuel. could have water or condensation in the tank. also if you let the level drop low it could start sucking sediment that settles in the bottom of fuel tanks
Jul 15, 2012 | Measuring Tools & Sensors
E ng lite came on pulled to stop light engine ran rough and was shaking ck oil was low filled oil ran better this am wife went to take truck to work got to the end of block engine ran rough brought back...
I don't think the rough running had much to do with oil level, since it started running rough a 2nd time. Check the fuel filter and ignition timing.
Sep 20, 2010 | 2002 Ford Ranger Regular Cab
1988 260E was running fine got on freeway after a few miles car began sputtering low fuel light was on made it to station added 7.5 gal to tank started car stalled exiting waited 10-15 min started fine...
(if it is the gas version) disregard if diesel ( dot hav answer for diesel accept for the fuel pump) do not run ethanol in the car, run high octane with 2 cans off octane boost intell the ethanol has ran through... the ethanol is evaporating b4 making it into the intake system causing it to stall,,, and trough errors in the car... (even if you have ran ethanol for a long time, it is a problem that my never go away now) if u can run regular without ethanol
Dec 03, 2009 | 2008 Toyota Camry
Car wont start or if started runs poorly 98 ford taurus 3.0
check the fuel pressure or sounds like mass airflow metter itself
Feb 28, 2009 | 1998 Ford Taurus
Running rough
you need a new fuel pump
Jan 03, 2009 | 2002 Ford F250 Super Duty SuperCab
Sep 16, 2008 | 1998 Plymouth Breeze
Sep 06, 2008 | 1987 Ford F 250
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
