Question about Lexmark T Office Equipment & Supplies
Paper twists as it is entering X4550 printer
Good quality paper used
  • Official Brand Answer
  • 3,344 Answers
Leading cause of paper jams or misfeed is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Posted on Feb 09, 2012
SOURCE: Canon Printer Problem : paper twists to right when loading
I find that having too much paper in the carrier can cause this problem.
Another tip I use is to fan the paper before putting it into the carrier and make sure the guides are guiding and not holding the paper, i.e. don't get them too wide or too narrow.
Posted on Oct 25, 2007
label_chick
  • 407 Answers
SOURCE: paper being fed crooked on my lexmark x4550 printer
Make sure your printer trays are lined up properly for the paper size you are loading.
Posted on May 10, 2009
  • 42 Answers
SOURCE: printer says paper jam but thereis no paper in the
Are you sure there is no paper. Please clarify what you checked so far. Did you check the COMPLETE paper path?
Posted on Oct 22, 2009
  • 126 Answers
SOURCE: My Lexmark x4550 printer is not working . How can
Try uninstalling and installing the drivers again making sure you PC is talking to the printer correctly. See if this helps. Try to setup the printer from scratch.
Posted on Apr 11, 2010
SOURCE: Paper twisted while entering printer rollers and
Try to turn off the printer, open the compartment and check the roller. try to pull the paper and at the same time flip the roller in such a way that the paper will move out. If it is jammed and crumpled like what I exactly experienced earlier, remove the paper as fast as you can.
Turn on the printer, wait for the inkjet devices in a neutral position. Then insert the paper and start printing again. If it didn't work, try to hold the tip of the paper in horizontal manner while printing and make sure you remove the entire paper before the next page prints itself...
Posted on May 30, 2010
I have a paper jam in the printer lexmark x4550 and don't know how to get to it
If you're having trouble getting the paper jam from the feeder, you can open the cartridge area. You should be able to get a better hold of jammed paper out from there.
Apr 11, 2011 | Lexmark X4550 InkJet Printer
Why does my paper jam half way as it tends to
I had this problem till I started using heavier weight paper. My wife was buying the cheap really thin paper and it was no end of trouble.
May 27, 2010 | Lexmark X4550 InkJet Printer
HOW TO INSTALL LEXMARK X4550 WIRELESS ALL-IN-ONE WITHOUT A CD TO WINDOWS XP
From the manufacturer's web-site:
http://support.lexmark.com/index?page=home&segment=DOWNLOAD
enter 'X4550' and then select the device-driver for your Operating System, download it, and install it.
Apr 25, 2010 | Lexmark X4550 Multifunction Wireless Color...
Apr 11, 2010 | Lexmark X4550 Multifunction Wireless Color...
Where do I load the paper?
Here is a link to the User's Guide of the printer. Page 34 will show you exactly how to load paper and the different types of papers that you can use.
http://bit.ly/cVcVYr
Jan 28, 2010 | Lexmark X4550 Multifunction Wireless Color...
Paper does not feed into printer
Printer Lexmark X4550 not taking paper, (Quick Fix)
Hi, yes my printer had the same problem with the pick up rollers not taking paper,
and thought it would be a simple job to adjust the springs inside the printer? But no, I could not find to open the printer. So I devised a simple modification using a
thin flat spring I had taken from an old windscreen wiper blade. see instructions
Good luck, bigvern
Jan 10, 2010 | Lexmark X4550 Multifunction Wireless Color...
PAPER KEEPS GETTING JAMMED.
This could be due to several things. Here a very complete set of instructions on how to resolve and prevent paper jams in the X4550.
http://bit.ly/aO5xwd
Dec 18, 2009 | Lexmark X4550 Multifunction Wireless Color...
Lexmark X4550 - paper jam
My Lexmark did the same thing-if you can get in at the rollers to clean them that might help.
Jun 09, 2009 | Lexmark X4550 InkJet Printer
Paper being fed crooked on my lexmark x4550 printer
May 10, 2009 | Office Equipment & Supplies
Paper jam in the lexmark x4550
If you know someone who is handy with this kind of stuff, you should get them to open the printer up and remove the paper. You could also try to just send sheets of paper through to see if they can dislodge it (but that may cause paper jams as well).
Apr 11, 2009 | Lexmark X4550 Multifunction Wireless Color...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
