Question about Fahrenheat Electric Convector Baseboard Heater, 3'
Can't find replacement parts
I just purchased a home built in 1981 - it has intertherm heaters thru-out - 3-in floor models, 2-in wall (little - bathrooms), and 6 baseboard EBH - the little ones in the baths do not work at all - can not find parts for thermastats, and the baseboard ones all have the knob on side of units with OFF - 1-5 - no matter what number you set it on, you are blown away by the heat - can not control the heat - and can not find any replacement parts.
the thermostat is a 2 pole - cadet bought intertherm - but what do do about getting the replacement parts - i have searched all over - any help?
  • Fahrenheat Master
  • 3,081 Answers
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Posted on Feb 11, 2010
  • treefrogjone Jan 18, 2011
    My advice would be to add an external thermostat which is mounted on the wall just like any normal room thermostat. Thermostats like the Honeywell CT62B1015 can be used with baseboard heaters. These thermostats carry the full voltage and current load of the heater so you need to shut off the power to the heater and be careful when installing them.
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
I have an older rental home that has a wall heater, house built in 1960 and I need to purchase a cover, the dimensions are 18 1/2 x 70 inches HELP.
im sorry but you cant get a new cover for a unit that old the best you can do is try to find a used one mabey put a ade in the paper someone might have an old williams heater that dosint work inymore and might sell a cover to you.
Jan 21, 2011 | Williams (5009622) Ceramic Gas Wall...
What is an A-Coil Cage on a Intertherm Electric Mobile Home Furnace?
An "a-coil" is a cooling coil that looks like the letter "a". The cage is simply the box or sheet metal case built around the a-coil. It is most likely located inside of the furnace itself and if you remove the furnace door you should be able to easily locate the coil- it has 2 copper pipe tubes running from the coil and down or up through the ceiling or the wall.
Hope this helps, James
Jan 05, 2011 | Intertherm Heating & Cooling
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Fahrenheat Electric Convector Baseboard Heater, 3' Logo
763 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
