Question about HP Officejet J5780 All-In-One InkJet Printer
Why my HP J5780 printer making very loud cracking noise when it start to print
I do not know what more details I should provide; The noise started after installing new cartridges, then I check and it is correctly done. Prints and copying without additional problem but with very loud noise like from a machine gun.
myob247
  • 1342 Answers
SOURCE: makes noise
Click HERE for HP troubleshooting for your printer.
Posted on Jun 07, 2008
POCBM
  • 121 Answers
SOURCE: hp 3015 prints light with new oem cartridge
Machine may be in econo mode. To enable/disable.
Hope this helps
  1. open the Printer Properties (or Printing Preferences in Windows 2000 and Windows XP).
  2. On the Paper/Quality tab or the Finishing tab deselect EconoMode check box.
Posted on Apr 02, 2009
  • 1126 Answers
SOURCE: HP OfficeJet J5780 Vertical Black Line Prints when
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Posted on Sep 07, 2009
  • 71 Answers
SOURCE: loud clicking noise
we need to perform a reset, it will take the pritner to the factory settings and this may help you,
the process of reset goes like.
unplug the power cable from the pritner >
then press and hold down the # key and 6 key >
while pressing and holding these keys plug in the power cable back into the printer and wait for 20 secs and then release the buttons..
after this the printer will re-initialize and this might take few minutes.. so wait untill it finishes and follow the onscreeen instruction as well.(if any)
Posted on Nov 04, 2009
CW Oly
  • 240 Answers
SOURCE: The printer makes a noise that sounds like a
It sounds like the cleaning sled is binding. Likely due to ink sludge build up in the waste station. Look into the printer, on the right side, where the cartridge rest when not in use. If this area looks very inky your printer may need servicing.
Posted on Mar 18, 2010
WHEN THE PRINTER GETS STARTED IT MAKES A LOUD NOISE BUT PRINTS. NOW IT STOPPED PRINTING
Hey dude,
First check with the interface cable from system to printer.If when the printout is given it starts making noise,then the communication is ok.Now check with the Print driver ,try to uninstall and reinstall it.i assure it'll help so.
With hope,
Mar 06, 2011 | HP LaserJet 1000 Printer
My printer started making loud clanking noises immediately before printing the document. The document prints fine, but that loud noise sounds like a machine gun. After manually moving the carridge to the...
jim@bigdork.net
Thanks fixya.com
You helped me CLEAN the HP PSC 1610
it had MASIVE amounts of waisted ink
in the area that it WANTS to waste ink
to keep the cartridges FLOWING...
BUT... NOW ... HERE IS A SOLUTION TO
THE CLICKING NOISE
THE RATCHIT NOISE
HP PSC 1610 NOISE
It seems that HP (as with most all manufacturers)
has DESIGNED-IN A PART THAT WILL BREAK ! ! !
PICTURE ATTACHED
explanation...
opened the mid section of the printer
moved the ink holder module to the far left
pushed the cleaning tray
(it moves to you and away from you)
away towards the rear of the machine
used masive amounts of isopropyl alcohol
and an old toothbrush
to clean most of the gunk ink buld-up
(started with q-tips but it was not enough)
After cleaning ... the machine worked again...
BUT
that noise was still there
after carefull inspection
I saw the problem
there was a hairline crack in a small plastic part
above a rotating gear
when the carriage came to the right
it was suposed to move that part
off or away from the gear
but because it was cracked
it did not move properly
SOLUTION
crazy glue or super glue
and shim to hold in place while drying
(maby heat with a light bulb while drying)
SEE ATTACHED PHOTO WITH NOTES....
May 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
The printer makes a noise that sounds like a machine gun as soon as it starts to print, but just at that time and each time it prints. The noise does not continue, but stops once the printer starts...
Mar 18, 2010 | HP Office Equipment & Supplies
Hello, My J5780 Has Just Atarted Printing
In printer properties and then in printing preferences, look for and turn off mirror image printing, it's there for printing transfers to shirts and things that you need reversed.
Dec 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Loud clicking noise
Nov 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Uncleared print job HP J5780 I'm pulling my hair out trying to print to my HPJ5780. With a failed manual duplex job, I tried to delete the print job from the queue. It came up fine as deleting - however...
Try stopping the print spooler service and canelling all the documents.
The Windows Print Spooler is a Windows XP "Service". You can start/stop it via the following steps:
  1. Click on the Start button
  2. click on Run
  3. enter "services.msc" without the quotes and press Enter
  4. Scroll down to Print Spooler
  5. Single-Click on Print Spooler
  6. The details will open in the middle of the window.
    • It probably shows Start -- if so, Start it.
    • If it shows Stop and Restart, I suggest Stop it, then Start it.
Jul 16, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer HP J5708 doesn't work
Have you check if Device Manager entries for Printer and Drivers viz. USB etc are not marked..
Also let me know the Printer Spooling error if any come up exactly.
May be you have to go for reinstallation, let me know the details for further diagnosis.
Puneet Jain
Jan 02, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer only printing top half of line
I switched my printer off at the mains and back on and this rectified the problem
Nov 17, 2008 | HP Officejet J5780 All-In-One InkJet...
Makes noise
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
89 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
