Question about GE 30 in. JGP337 Gas Cooktop
Replacing burner bowl on GE JGP 337 cooktop
I want to replace the burner bowl because it is discolored. I removed the screws but I cannot loosen the ignitor.
2 Suggested Answers
SOURCE: how do I remove the spark igniter when replacing a burner bowl
The spark ignitor is attached to the burner bowl by a retaining clip under the bowl. Simply remove the two screws on the top of the bowl, then you can slide the clip off from the underside
Posted on Jun 28, 2010
GE cooktop ignitor jgp
Look for a short in the wiring (usually white wires running to the ignitors) or a loose ground wire. (usually green)
Jul 02, 2012 | GE Cooktops
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
GE Cooktop drop-in model # jgp328bec2bb - how to take apart the cooktop,I need to replace the spark ignitor switch harness.
Turn off the gas,unplug the power.
Take the cooktop out of the cutout and support it on the countertop.
Remove all grates and valve knobs.
Remove all screws from the valves and the burners.
Remove the burner base plates.
You may have screw on the side holding the top to the base,if so,remove these too.
The top will separate from the bottom exposing your parts.
Feb 11, 2010 | GE 30 in. JGP328 Gas Cooktop
How do I remove the spark igniter when replacing a burner bowl on GE JGP 636 gas cooktop
Jan 23, 2010 | GE 30 in. JGP326 Gas Cooktop
We woke up this morning and our JGP 336 is sparking on its own on all the burners randomly.It didnt get wet??
You have a stuck ignitor switch on one of your burner valve stems.
Remove the front panel. Remove one wire at a time from each switch. When the clicking stops that will be the bad switch.
Jun 17, 2009 | GE 30 in. JGP336 Gas Cooktop
Ignition of burners is difficult and uncertain.
remove the burner caps, or heads and check all of the ports to be sure they are not clogged. Also be sure that when you put them back that they go into the correct positions.
Apr 09, 2009 | Cooktops
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Does not ignite
Check to make sure that the gas is getting to the igniter. If you can ignite with a lighter or match, than the igniter itself needs to be replaced.
Apr 01, 2009 | GE 30 in. JGP326 Gas Cooktop
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
GE 30 in. JGP337 Gas Cooktop Logo
87 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
