Question about Lexmark Office Equipment & Supplies
Lexmark X83 - Changed the black cartridge according to the instructions. Message says Warning low on black ink. Page prints so faintly can't be read.
  • edwinaelora Oct 23, 2008
    what do you mean clean
    Genius:
  • 1,913 Answers
Refix again cartridge also check there is not any paper jam or lekage in cartridge.
clean on bottom surface of cartridge on which u put it.
Posted on Oct 23, 2008
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Changed black ink caertridge but still getting the low ink warning
If you are using a remanufactured cartridge, the low ink warning is actually normal. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridges are remanufactured, the chip is unable to be reset. Here is a link to a site that sells remanufactured cartridges on how to bypass the low ink warning on Lexmark printers:
http://swapink.com/Merchant5/merchant.mvc?Screen=lexinst
Nov 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Lexmark X83 prints streakily or not at all
Have you used a new cartridge.
Do the test for running and cleaning new cartridge heads and the alignment procedure..
(Go to Start, settings, printers, right click on printer then click properties, cartridge maintenance.)
Other thing that might cause problem is build up of ink in right side of machine below printer cartridges.
You will have to strip down machine to get at this area.
Make a note of exactly what action you take when doing this so that you can bits back together.
I use cotton buds to get at the build up of ink or tissue wound round end of pointed object.
Go gently. When you have cleared what you can care reassemble bits and go through above procedure again. Check for any unusual noises that may denote part of mechanism has worn.
Alleluia
PTL
Nov 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Lex 5150 - not printing black well
what you may have to do is clean the rollers, good place to clean is where you insert the cartridges, open the lid so the machine thinks your going to repalce the ink, cut the power from the mains, now you can proceed to to clean the inside, remove both in cartradges and clean where they instert, toilet roll or kitchen roll will do because they soak up the ink, then, and be very gentle, slide the mechanism to the left hand side so you can clean underneath, after cleaning power the printer up so that it still thinks you are changing the ink, the cartridge housing should be where you can access them so you can the put the ink back in, then you need to use the the lexmark software to re-align the cartridges and also print a test page, keep on doing this until the inkjets are performing properly
Nov 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X83 Changed black cartridge print warns Black ink low Prints so faintly can't be read
the printer heads probably need cleaning. If you go to control panel>printers and scanners> right click the printer you are using> click in properties, there should be an option there for maintenance. Choose clean print heads. When the heads have been cleaned print out the result. If this has improved but is still a bit faint repeat the steps until the page is clearly readable.
Oct 22, 2008 | Lexmark Office Equipment & Supplies
Black cartridge not activating properly
There's a blue protective strip on the bottom of the cartridge when you buy it, and it needs to be removed before you put the cartridge in the printer.
May 16, 2008 | Lexmark X83 All-In-One InkJet Printer
Printer won't recognize new ink cartidge
Most common problems like this come from non-genuine cartridges, or refilled ones.
Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 Printer Copier Scanner
when u refill the ink in cardge so its cant detact thats y the earror is coming due to its compny ink its happen in all prineters
Feb 26, 2008 | Lexmark X83 All-In-One InkJet Printer
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
