Question about Sony TC-WE635 Single Cassette Deck
REPAIR MANUAL FOR SONY MODEL # TC-WE635 - Sony TC-WE635 Single Cassette Deck
TC-K61 Limited Edition. Turns on. Belt is spinning and the bottom mechanism comes up then goes back down. What's wrong?
A loose belt ,or a dirty mode select switch everything is timed the motor is allways turning but the play function is electro mechanical timed and if the belt is to loose its slipping on some points.
SONY TC K61 Service Manual free download schematics eeprom repair info for...
Apr 14, 2016 | Sony Audio Players & Recorders
Where can I find an owner's manual for Sony TC-355 tape recorder
Hi Cloise,
Go to HIFI engine at this link. Sony TC 355 Manual Stereo Tapecorder HiFi Engine .
Here is the TC355 page. Sony TC 355 Manual Stereo Tapecorder HiFi Engine
You must create an ID and Login to obtain the free download.
Fare. Well.
Dec 12, 2014 | Sony Audio Players & Recorders
Need to buy belts
Most belts are universal. You only need to measure the diameter of the belt in mm and search Google for cassette drive belt xx mm. Generally you don't need to get the measurement spot on. A 52mm belt for example could be replaced by a 50mm or a 55mm.
Mar 20, 2014 | Sony TC-WE635 Single Cassette Deck
"A" side/deck wont play----"B" deck works just fine
Loose belts and lack of lubrication. Dual cassette decks are built to minimum standards so that it does not take much to push them over the edge to be non-functional. It is almost like they should provide a tape deck repair course with these types of units as it is most certain that you are going to need it. They want you to throw it away and buy another one. This is where the throw away economy started.
Jan 27, 2013 | Sony TC-WE635 Single Cassette Deck
Requestin replacementsize of belts for Sony TC WE305 cassette player, not a boombox
A Tv repair shop carries a large stock of belts, probably a good place to start. The other option is order from Sony online and ask for the Technical Department.
Feb 17, 2012 | Audio Players & Recorders
I need instruction manual for Sony cassette deck TC-WE 675. Can I download this?
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
Aug 31, 2011 | Sony TC-WE675 Single Cassette Deck
Where can I have my 15 year old Sony Model TC-WR465 Stereo Tape Deck Repaired? The problem appears to be mechanical. The tapes will not advance on either side of the unit.
Depend on your location and willingness to ship the unit. The cost of the repair must also be weighed in. If you don't want to put $100 into it I don't think most shops these days will want to open it up. Dual cassette deck are notorious for failure due to cheap design. Look around at all the problems. I have been fixing units for 40 years and even at Sony and Sony authorized.
I can look at it at Skywave Tape Deck Repair in Chicago area if you want. Google it.
Aug 09, 2011 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC-WE635 Single Cassette Deck Logo
117 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
