Question about Lands Phones
How can I download qeep on blackberry curve 9300? Thanks.
SOURCE: my keyboard backlight for blackberry
I found out on here how to fix it. You take the battery out, while the phone is turned on, leave it for 30 secs then put it back in. So far it seems to be working.
Posted on Jan 18, 2011
SOURCE: hi there i have downloaded
Hi,you could try this, it worked for me, might not work on all black berry,But you could try itout and get back to me it if helped.
RESET BLACK BERRY
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Good luck
Thanks.
Posted on Feb 09, 2011
Geekman
  • 32281 Answers
SOURCE: PUK code for my blackberry
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Posted on Mar 19, 2011
  • 1487 Answers
SOURCE: RIM BlackBerry Curve 3G 9300 mep code 0
There is one option left to unlock blackberry curve 3G 9300 if your mep counter attempt to 0, in this case blackberry unlock code will not affected anymore. You must doing cable unlocking process, this method will force your blackberry unlocked and you can do that at mobile repair shop.
Posted on Oct 28, 2011
SOURCE: how do i clear error 40820 on blackberry curve 9300
Go to my account on bb app, go payment option, it will ask you to sign in your bb id, sign in. when it turn another error, try to sign in again until it comes out to choose between pay pal or credit card. when it appears to that, you can back and download anything. this worked for my bb9900. if the error still appear, try until you succeed. i tried like 3 times. hope this help.
Posted on Jul 31, 2012
Is it possible to download instagram on blackberry curve 9300?
you can only download with blackberry if your browser is unlocked,or via wifi.
Jan 20, 2014 | MYBAT BlackBerry Curve 8520, 8530, 9300,...
Blackberry curve 9300
Simply you can purchase unlock code for Blackberry curve 9300 from any vendors online like UnBBlock.com just insert it and your network lock will be opened
Nov 12, 2013 | Computers & Internet
BlackBerry curve 3g 9300 locked to code
Hi, You can get the unlock code for a Blackberry 9300 Curve 3G from www.mobile-unlocker.com at affordable cost with easy unlocking guide. Good luck mate.
May 23, 2013 | Research In Motion BlackBerry Curve 9300...
Download skype on blackberry 9300
please Type google download skype on blackberry 9300 Free download
Aug 04, 2012 | RIM BlackBerry Curve 3G 9300 Cell Phone
I have blackberry curve 9300 it is on Vodafone and i need the unlocking code to all network
You can get the unlock code for Blackberry curve 9300 from any trusted vendor online. for example, you can choose http://www.Mobile-unlocker.com/ This is one of the trustworthy site providing accurate unlock codes at affordable cost. Unlocking process here is very simple and easy. You will get complete guidance on unlocking process from here. All the best mate
Apr 09, 2012 | RIM BlackBerry Curve 3G 9300 Cell Phone
Oct 24, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
I want unlocak my blackberry mobile 9300 curve plz tell me how can i do
Get the code from service provider and Unlock it...
Aug 27, 2011 | AT&T Cell Phones
MPE UNLOCKING CODE FOR BLACKBERY 9300 CURVE
you can Unlock your Blackberry 9300 Curve with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry. get your Blackberry 9300 Curve Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Jun 23, 2011 | AT&T Blackberry Curve 8300 Smartphone
Is it possible to get an unlock code for a blackberry curve 9300 IMEI 353039041609422?
It is very simple to unlock your Blackberry curve 9300 through Blackberry Mep Unlock Code. call your service provider . or buy your Blackberry curve 9300 Mep Code from third party. it is safe and trusted method to Unlock your Blackberry curve 9300.I hope this will help you :)Good Luck.
May 13, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
Lands Phones Logo
42 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
