Question about Pulsar Chronograph PF8037 Wrist Watch
What is the battery life of a Pulsar PF8037 watch?
I HAVE A PULSAR WATCH # 094894 WHAT BATTERY DOES IT TAKE
Take your Pulsar watch tp a jeweler who will remove the back, identify the battery type, and perhaps replace it, all for a reasonable sum.
May 20, 2018 | Pulsar Watches
What is the battery replacement # for a pulsar n944 6a00 ?
BATTERY CHANGE The miniature battery SEIKO SR927W which powers your watch should last approximately 2 years. However, because the battery is inserted at the factory, its actual life once in your possession may be less than the specified period.
Mar 24, 2016 | Pulsar Watches
Put new battery in pulsa chronograph 100m watch how do I get it working Plz help
You might need a jump start the watch, or cleaning. I usually try using a air dust blower ball to get all the particles that is invisible to the eye, you can do this on the movement and around the battery area. Aftwards try inserting the battery again then pull out the stem and move it clockwise at least 10 times passing the 12'o clock marker. If the watch is not brough back to life you can try one last thing before buying a new movement or taking it to the watch repair shop. If you take it to watch repair shop they might charge you a few bucks to jump start the movement. I hope this helps. Marcelo
Oct 22, 2013 | Pulsar Chronograph Watch
What type of battery does a Pulsar pxh227 watch take?
The Pulsar pxh227 uses a sr920sw silver oxide battery. An AG3 alkaline battery will also work, is cheaper, but will not last as long as the sr920sw.
Oct 12, 2013 | Pulsar PXH227 Wrist Watch
Pulsar solar watch repair, stopped running
They have a rechargeable battery in them,you'll have to go to jeweler or a watch repair store.the battery is not cheap!!! I had my wifes fixed a few years ago the battery cost $68.00,but she likes the watch so it was worth it.
Jan 17, 2013 | Pulsar Watches
Which watch battery fit my Pulsar?
372 or 373, they are interchangeable. It was listed under Seiko and not Pulsar.... the key model # is the vx43, the rest wasn't used. My source: MAXELL 373 SR916SW 1 Battery Official OEM 372 373
Feb 28, 2012 | Seiko Watches
Pulsar chrono hand alignment
mcdedevito75 here, Return to the watch rep[air that installed the battery for adjustmaet.
Jul 03, 2010 | Seiko Pulsar watch
Battery problem
Stop panicking, please. If you lost the battery, that means your watch has been opened, so, read the movement number and submit here. Then Ill be able to give exact battery number.
Apr 14, 2010 | Pulsar Expansion PPH520 Wrist Watch
Pulsar Chronograph PF8037 Wrist Watch Logo
32 people viewed this question
Top Pulsar Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
