Question about Singer Sewing Machines
Singer 1570 dial settings
  • kim clements Feb 08, 2012
    Please can you tell me what settings the dials need to be on :)
  • Singer Master
  • 7,365 Answers
What dial setting do you need? straight stitch or zig zag?
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number 1570
Click search & the page will show what manuals are available
Posted on Feb 09, 2012
My new Singer 4411 will not do zig zag or other stitches, just plain sewing
josephamoi Nov 17, 2017
When sewing ziz zag stitches the zig zag dial on your top right hand must be set any thing thing above 0. The setting is 0 to 6. Only on straight stitch this dial be set at zero.
Nov 15, 2017 | Singer Sewing Machines
Stitch option settings dial not responding
An older mechanical machine? Possibly could use a good cleaning and oiling. Old oil may have solidified and preventing things from moving.
Wheel on right side that controls the needle up and down is very tight...
Apr 12, 2017 | Riccar Sewing Machines
Singer simple, tension setting What should my settings be for a simple straight seem with my Singer Simple sewing machine?
The factory default is the middle of the tension dial (midway between high & low numbers). Then usually it takes a bit of tweaking to get it where you want it.
Nov 15, 2016 | Singer Sewing Machines
I have a Singer model #6105, what do I set my stitch lenght to and what do I set the tension dial to for just regular sewing?
Your upper tension dial should start at 4 to 5. The stitch length should be at 2.5, or 3. Make sure your settings are on straight stitch, and the rest are set in the middle. I've worked on one of these, and it's a nice little machine.
Feb 15, 2015 | Singer Sewing Machines
How do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
Aug 20, 2012 | Singer Sewing Machines
Singer Merritt 3015 Tension
the tension dial may be going out & need to be replaced at a sewing machine repair shop
May 20, 2012 | Singer Sewing Machines
Model 4423 singer stuck in reverse
Solution: Turn off machine. Turn stitch dial until you hear click on each stitch shown on dial. Set to straight stitch then and set stitch width to 6. try machine again being careful to put light force on the foot pedal so your not going full throttle. This is how I "de-confused" my Singer Heavy Duty 4423 when it got stuck on reverse. Hope this helps!
Jimmy
Mar 20, 2012 | Singer Sewing Machines
I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Aug 03, 2010 | Singer Sewing Machines
Need to know how to the zig zag stitch on the 132 featherweight machinge by singer.
By turning the bottom dial on the righthand side of the machine, you can change type of stitch. For zig zag, you need to set it to B (seen on the front of the machine). You can adjust the width of the zig zag using the same dial.
Mar 04, 2009 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
100 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
