Question about Konica Minolta Cameras
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
First time this happened (it has acted up 1-2x prior but more like the battery was dead and after changing Batt. it worked fine) after I let sit overnight with no battery it worked ok the next day. Then 7 days ago tried to turn it on and once again weak light/sound for sec then nothing. Tried to change batteries, let it sit empty for a bit, cleaned connections...still nothing. When i got home I check the batteries on my backup camera and all worked fine. Have been letting it sit empty since and each evening I check to see if it will power up...nothing but the weak light/sound then nothing.
  • 734 Answers
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Posted on Feb 09, 2012
No picture, No sound
It sounds that the IIC Bus circuit shorts bey some faulty components connected to it. The troubleshooting work to this section circuit is very skilled one. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Digital Lifestyle FA1B32Z 32 in. LCD...
Flashing green power light
If the model indicated here is right It could be in the power supply and this model sometimes fails where light just blinks--that could be also convergence issue--in this model there is a way to disconnect the power going to the convergence board to see if set will then turn on.
Jun 14, 2012 | JVC AV-65WP74 Rear Projection Television
What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Nov 18, 2011 | Goodman Heating & Cooling
Yellow light flickers 4 times when trying to turn
If you don't get the flickering lights when you try to boot up with the AC adapter hooked up but no battery, it sounds like the problem is most likely a bad power adapter. Your battery is dead, and that's why you get the flickering lights, but the AC adapter is bad so you can't use it to power the laptop or charge the battery.
You can typically get a new adapter for $20 or so, or maybe even cheaper on eBay.
May 29, 2010 | Toshiba Satelite A10 Notebook
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
Each time i try to turn on my Toshiba Satellite L305 ( laptop), the on light goes on, but nothing else happen's, the hard drive light does not flicker and the screen stays black. The airport light usually...
Removed the power conection and remove the battery as well and press and hold the power button for 5 to 7 sec and then connect the battery and power cable and try to turn on
Regards
Samson Ved
Dec 05, 2008 | Computers & Internet
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Samsung model#TX83082WH
you have a weak power supply its simply trying to go out on you
Mar 14, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Failed on restart, had all lights, now no lights and won't do anything!
sounds like your ac plug to the laptop might be loose you can try ans see if you can resolder it back. the other problem is your ac cord might be broken wiggle it around see if the light flickers.
Jan 03, 2008 | IBM ThinkPad R50e Notebook
Cameras Logo
89 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
