Question about Maytag 24 in. MDBH965AW Built-in Dishwasher
Maytag MDBH969AWW1 Quit
During the beginning cycle, I opened the door to add an item (as I knew I could do), and the lights on the control panel just went out. Assuming it had tripped a circuit breaker, I checked. No deal. Nonetheless, I turned off the breaker for 1/2 hour, then switched it on and tried to press and hold the unlock (heat) button. Still nothing. Is there a different reset? The owner's manual troubleshooting was of no help. Thank you in advance.
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
  • 142 Answers
SOURCE: Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Posted on Jan 27, 2009
  • 10865 Answers
SOURCE: maytag mdb6100awb trips circiut breaker after 5-10 minutes in use
The first thing I would do is install a new circuit breaker. That could well be your problem.
Posted on Jun 18, 2009
localwonder
  • 6784 Answers
SOURCE: No Power, No Lights on MDB7100AWQ
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jul 13, 2009
  • 441 Answers
SOURCE: How to reset dishwasher maytag MDB9601AWB?
let the breaker sit off for an hour, if that does not work it needs help
Posted on Nov 17, 2009
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
I have the Kenmore front load washer HE2. How do I use the clean washer cycle.
Hello, welcome to FixYa.
In order to perform a "clean" on the HE2 is as follows...Read these instructions completely before beginning the cleaning process.
**If necessary, the cleaning cycle may be interrupted by pressing STOP. This will stop the cycle. A RINSE/SPIN cycle must then be run to thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage to the unit and clothing added to the next cycle.**
Begin procedure
1) Open the washer door and remove any clothing or items from the washer.
2) Be sure the door is closed.
3) Open the dispenser drawer and immediately add 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to this cycle. Use of more than 2/3 cup (160 mL) of bleach will cause product damage over time.
4) Be sure dispenser drawer is closed.
5) Select the CLEAN WASHER cycle.
6) Press START.
NOTE: The basket will rotate, then the door will unlock, lock again, and then the cycle will continue. The machine will not fill, but the basket will rotate while the washer runs a short sensing cycle. This will take approximately 3 minutes.
7) The cycle will determine if clothing or other items are in the washer. a) If no items are detected in the washer, it will proceed to step 8. b) If any items are detected in the washer, all cycle lights will flash and "rL" or "F/34" will be displayed. Associated LED status lights will remain lit. The door will then unlock. Press STOP to cancel the failure code. Then repeat steps 1, 2 and 6 to start the cycle again.
8) Once the cycle has begun, allow the cycle to be completed.
9) After the cycle is complete, leave the door open, slightly, to allow for better ventilation and drying of washer interior.
Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
Green light on control panel constenly blinks
This condition can also apply to a dishwasher that has had the electronic control replaced.
A heater fault detection program has been added to the
electronic control to check for temperature rise and shut
down the dishwasher if a temperature rise is not detected.
The cycles have been modified to add 8 minutes 45
seconds of fixed heat at the beginning of the main wash.
If the temperature rise is less than the criteria, then
the unit will drain and blink the clean light 7 times. The
detection will be ignored if the temperature is out of its
normal range, 64° - 160° F, or the door is opened during
the fixed heat.
Once a heater fault is detected and the condition resolved
the electronic control must be reset by initiating a service
diagnostic cycle.
Sep 17, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dishwasher just quit during the cycle but it still has power going to it none of the lights on the door will work now and it wont restart
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
Jan 03, 2010 | Maytag MDB4621AW Built-in Dishwasher
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Maytag MAH8700 - NP error code - Door locked and won't open
I don't know if you are aware of this, but Maytag did a recall on this washer in March 2007 where there was a risk of water leaking into the control panel and shorting out the board. You can follow this link to see if your washer was affected based on the serial number:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07135.html.
Here is a link to your user manual to see if it offers any help. The only thing I saw was to use the Cycle Selector button to unlock the door.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/DC6802030B01.PDF
I found this on the Maytag site:
Is the door locked and the Add A Garment or Add Clothes light off?
If the Add A Garment or Add Clothes light is off, then the washer door will unlock after the Pause/Off or Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
You could also try their customer service number to see if they have a script for this problem: 1-800-688-9900
The only other solution I can offer is to disassemble your washer if its that urgent and you can't get a repairman out there.
Jan 10, 2009 | Maytag MAH8700AWM Neptune Front Load...
Control panel lights OK; Won't start into cycles
Hey, just had the same problem with my 9150. Moisture got into the electronic key pad. $300 to replace it. I was 5 months out of warranty.
I called 800-688-9900 and Maytag agreed to cover the part and we have to cover the labor. Not completely satisfied but a little bit helps.
Jan 09, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag 24 in. MDBH965AW Built-in Dishwasher Logo
158 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
