Question about ViewSonic VG900b 19" LCD Monitor
Monitor problem - Dark colors, slow screen refresh
I have a Viewsonic VG900b monitor that recently just started to show some very strange problems. First the colors have all gone dark, as if someone had turned down the Brightness all the way. I can still see everything, it's just very dark.
More annoying though is that the screen refresh is painfully slow on all operations. Moving the mouse is a chore, with the screen being refreshed about one time per two seconds (fading from one refresh to the next). Even pressing the 1 and 2 keys on the monitor have a very slow (and fading) refresh, and "Auto Adjust Image" and "Screen Resize" have no effect. Also, I have switched this monitor to other Windows AND Macintosh computers with the same result, so I'm pretty sure it's not a software driver problem.
Can this monitor be saved, or is it toast?
Thanks in advance.
  • Anonymous Apr 14, 2009
    how long does an lcd monitor last?
  • mapwu Apr 15, 2009
    I also have seen this problem with my monitor. The monitor I have is a flat panel LCD display that is 2.5 years old. I was working on the computer when the "ghost" took over the machine. By that I mean I saw the event that initiated the change. A dark 'cloud' traveled across the screen, from the upper right to lower left, and then the whole screen dimmed and began having more and more refresh rate problems. The mouse cursor would show a trail, and the mouse was often not visible. To find it, I would move it quickly back and forth and the 'column' of pixels that contained the mouse would show brightness at the top of the screen. I went out and bought a new 23" monitor and am happy with it.
    But I want to fix the other one. Could it be a power supply problem?
    How long should these monitors last?
    Mine was a HP f2105.
    Guru:
  • 722 Answers
It sounds to me like the picture tube in the monitor is going out. I began to wonder if it was your video card until you mentioned that you used it with various computers. This tells me it's the monitor itself. Unfortunetly, I think your monitor may be due for retirement.
Posted on Mar 31, 2009
We have a Viewsonic VG900b monitor that recently just started to show some very strange problems. First the colors have all gone dark, as if someone had turned down the Brightness all the way. I can still...
Check the two insertion ends of the power cable and ensure that they are well fitted in. Check your area power voltage range and ensure that the monitor complies with specification.
Make sure you are using the right and GOOD power cable.
Lastly, Unplug from the monitor from the system and allow to cool for a good 3 hours or better still, disengage it from duty for 1 day and start using it the next day.
Do you have enough ventillation there?
Don't forget to rate me and get back to me if this helps. Tnx.
Jan 10, 2011 | ViewSonic VG900b 19" LCD Monitor
Monitor displays then shuts off
Have you verified the video card in the computer with a different monitor? Does the going to sleep message come up prior th the monitor going dark? The bulbs are ok since you do see a picture for a short time. The voltage swing you see on the power supply is too large. It should always be 12 v + or- 10%.
Mar 28, 2017 | ViewSonic VG900b 19" LCD Monitor
After 5 minutes monitor screen dims--can faintly see the windows screen and then it flickers out and there is nothing. Any ideas?
the monitor may be going into power save mode which it should come out of when you press a key or move the mouse but it sounds like you have tube inverter issues. Your screen has light tubes behind it to illuminate the screen, if the tubes or the inverter develop a fault, then a very dark screen can result as the tubes are turned off. There may also be an ambient light sensor which will darken the screen in low ambient light. If the sensor is faulty, darkened screens will result. If the inverter is failing, you may be able to replace it, contact viewsonic. if the tubes are failing, replace the panel or the entire monitor. If the ambient light sensor is faulty, replace the panel or entire monitor as the sensor is part of the display panel.
Nov 02, 2009 | ViewSonic VG900b 19" LCD Monitor
Viewsonic vg900b turns on, and turns off after 1 second
bad board inside do to heat clean your new one more offen. replace monitor.
Sep 08, 2009 | ViewSonic VG900b 19" LCD Monitor
Monitor has developed a permanent dark turquoise hue.
Did you ever try the original monitor on another machine. If the new monitor is displaying the same symptoms as the old one then your video card is the culprit.
Mar 25, 2009 | Dell E176FP 17" LCD Monitor
Monitor flickers unless brightness is at 100%
Try monitor menu select Memory Recall and press that, should clear right up
Mar 08, 2009 | ViewSonic VA1912wb Monitor
Scrolling lines on monitor
Weird... if there's still warranty on the monitor see if you can get it fixed or replaced with a new one.
Mar 06, 2009 | LG W2252TQ Monitor
Viewsonic vx2245wm
You need to chk graphics settings in NVidia control center and change resolution until it looks right
Mar 06, 2017 | ViewSonic VX2235wm LCD Monitor
Viewsonic VG 900 displays briefly, then goes blank
What Usually causes these to go on and off quickly is one af a couple things.
Usually it is the powerboard not putting out enough power to run the video board and the inverter.
Sometimes it is the actual inverter board. I have seen a plain small fuse stop these cold.
Rarely, but it could be a bad bulb in the screen. Bad bulbs usually start dark in the middle, or they start off pink. They can also flicker while they are on.
If you can take it apart and have a dc tester, the problem may be able to be found.
I repair some viewsonics , mostly VXs series, but I have done a couple of these.
bammbammfran
Oct 11, 2008 | ViewSonic VG900b (Black) (10 Pack) Monitor
ViewSonic VG900b 19" LCD Monitor Logo
398 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
