Question about Electrolux 30" Self-Cleaning Freestanding Electric Convection Range - White
Electric range F codes
Es300
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
Apr 05, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire es300 gas range kepps flashing f10 and f13.how to resetand get the clock working
Hello Carol Martin - Typically, error codes F10 and F13 could indicate a variety of issues. The range could possibly have a shorted keypad, runaway temperature (higher than normal temperature), faulty EOC (electronic oven control) or, display wire harness missing/not connected. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Mar 06, 2013 | Frigidaire Gallery GLEFZ384GC Kitchen...
Gas range says dr how to fix it
Hello robin_deathe - Will the door look? Is the door lock indicator light glowing? Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately one minute and turn the range back on. This will clear most false error codes. If error code still displays on panel, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty light switch, door latch or EOC.
Oct 02, 2012 | Frigidaire Ovens
I have an es300 gas range and the bake doesnt work...the broiler does work...but when i want to use the bake it doesnt even sound like it wants to ignite
This is usually the ignitor is not reaching the proper amp draw. For a free video on performing this test and troubleshooting the problem go to www.appliancehelponline.com/servicemanual.html this will walk you thru the process
Mar 27, 2010 | Frigidaire PLEF398AC Electric Kitchen...
ES300 Frigidare electric range bottom element melted. Do i need a repair person to check out the range or can i just replace the element? range is only 2 yrs old and hardly used. has there been a recall...
You can replace this element yourself and it is not uncommon for elements to melt if you don't catch it burning when it first catches on fire. This is scary, but normally, the element burns itself out on it's own and doesn't catch anything else on fire.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and remind us of your model number and we will get the correct part out to you asap.
You can save a lot of money by making this repair yourself and we'd love to help you save some money.
Thanks, Ella
Jan 20, 2010 | Frigidaire PLEF398AC Electric Kitchen...
I have an F5 error message..What does this mean....Fridgedaire es300
The failure code list says to replace your Electronic Oven Controll. Contact a Frigidaire parts dealer and check the price and availability.
You will need to give them your make and model number.
Buckle up! It may get expensive!
Jan 28, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Is their a reset button on a frigidaire elctric range model ES300
clock, timer, temp gauges for oven shorted out, is there a reset button?
Jan 09, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire es300
you could have a power problem.. the stove will still work with half the power..like the burners on top will work. if thats not it. the wirers could be crossed or you may have a thermal cutout thats bad. but when the tco is bad broil and bake should not be working.. hope this helps
Feb 27, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Electrolux 30" Self-Cleaning Freestanding Electric Convection Range - White Logo
49 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
