Question about Admiral 24 in. DWUA800AA Built-in Dishwasher
Dishwasher is leaving food particles everywhere
When we bought the dishwasher a couple of years ago, we insisted on getting one that has some sort of food grinder in it (don't know what that's called). It's been washing fine until recently, The dishes get clean except there are food particles everywhere in the washer and on the dishes. So it gets the food off the dishes but the food doesn't go anywhere. Please let me know what I can do...thanks, Gena
    Problem Solver:
  • 12 Answers
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here http://www.appliancepartspros.com/partsearch/model.aspx?model_id=41284 then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 Hope this helps, APP tech http://www.AppliancePartsPros.com
Posted on Aug 08, 2006
I have a kenmore elite dishwasher model 665. it is several years old, and within the last year, it leaves food particles in glasses, etc... i tried different detergents and switched back and forth...
There should be a filter in the bottom under the spray arm. There should be 4 to 8 screws to remove to get to the filter, and clean.
Jan 27, 2013 | Dishwashers
Dishes leave food particles on the glasses - machine is only 2 years old. We use rinse agent - Cascade gel in the auto dispenser - we use jetdry dishwasher cleaning agen monthly - jet arms are not...
Recent changes in the law prevent soap makers from putting phosphates in dishwasher soap so they're not as effective as the were even a few months ago.  Unfortunately,  the solution is more thorough rinsing before loading.
http://www.appliance.net/2010/states-ban-phosphate-laden-dishwasher-soap-1988
Mar 03, 2011 | GE Dishwashers
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher wont drain after rinse cycle . Moffat Quiet One
My dishwasher runs but just does not clean and leaves food particles all over like its not getting clean water to it. I cleaned the passages of any food from the top end. Any suggestions. Its a moffit MLD4007l20ww
Feb 20, 2010 | Dishwashers
Dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
Jan 02, 2010 | GE Dishwashers
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 | Dishwashers
Dishwashers Logo
7,340 people viewed this question
Top Admiral Dishwashers Experts
Paul Bade
Oloyede Monsuru
Melissa Martin
Melissa Martin
Are you an Admiral Dishwasher Expert? Answer questions, earn points and help others
